ESP light ONLY (nightmare) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-23-2015, 02:18 PM Thread Starter
VolJeeper's Avatar
My 2014 JK Sport is stock except for bumpers and a set of 305/75R16 Adventuro M/T's. About a week after I installed the new tires and wheels the ESP light came on and ABS started to lock up on me a bit now and then (but no ABS light). When it starts freaking on me, all that happens is the ESP light blinks a couple times. Since the issue started I have had my tires toed in correctly, caster and camber checked out in spec, my steering wheel has been centered, tire balance checked and they are good, all four brake/wheel speed sensors checked and are good and Jeep has been flashed for larger tires. Beyond all of that, what else could possibly be causing this?! The nightmare part of the title was the 2,000 mile trip I took from Northern NY to southern TN and back this past week with no cruise control. My foot and leg are now killing me!
VolJeeper is offline
post #2 of 9 Old 03-23-2015, 02:20 PM Thread Starter
VolJeeper's Avatar
Addition. The light doesn't come on after I start driving. It remains on at all times. Before I even take off and the light never goes off with the rest of the Christmas tree when starting up.
post #3 of 9 Old 03-23-2015, 02:22 PM
snaggy's Avatar
You need an AEV Procal, Superchips or similar to correct for tire diameter difference. The factory cal is based on stock tires and the ABS and ESP rely on that. I use a Procal $159 at Quadratec
snaggy is offline
post #4 of 9 Old 03-23-2015, 02:25 PM Thread Starter
VolJeeper's Avatar
I have a Flashcal. Corrected diameter with that already.
post #5 of 9 Old 03-23-2015, 03:41 PM
Have you tried disconnecting the battery? It might reset it.
motorcycle matt is offline
post #6 of 9 Old 03-23-2015, 03:55 PM
Mark915's Avatar
This happened to me on Friday I changed tires from 35s to 37s and installed a drag link flip. It sounds like your steering wheel is off center. Or the abs/brake control module "thinks it is" i had to adjust the drag link little by little (both ways) dive it after each adj. till the light/s went off. I have a 2010 thinking I wouldn't have that problem but i did. hope this helps. There are plenty of posts on this.
Mark915 is offline
post #7 of 9 Old 03-23-2015, 04:20 PM
SilverBulletJKU's Avatar
This sort of thing happened to me as well. I have a 2015 and after I installed everything and having everything (except for the steering wheel) checked, my front breaks started to freak out! I'm pretty sure that it was the abs computer having a little glitch but I'm not sure. It happened to me twice a few weeks ago but hasn't done it since. Just like Mark said, the steering wheel could be the problem. When this happened to me my steering wheel was off line. Hope this helps man!
SilverBulletJKU is offline
post #8 of 9 Old 03-23-2015, 06:07 PM Thread Starter
VolJeeper's Avatar
I might have to find someone with a Procal because my Flashcal doesn't do the centering thing. I had the stealership center it when they did the alignment, but the light has still been on. I'm guessing that maybe what "looks" centered and what actually is might be two different things.
post #9 of 9 Old 03-24-2015, 08:39 AM
Pro Cals like most electronic automotive products are VIN# incripted so they will only work on that particular vehicle unless restored to stock. You'll have to buy one.
scubatech is offline
