Ripp'd JK P0174 and horrible gas mileage - JKowners.com : Jeep Wrangler JK Forum
post #1 of 38 Old 03-17-2015, 11:48 AM Thread Starter
leman's Avatar
I really wish my jeep could go atleast 1 day without something going wrong. last night while driving home the CEL came on no misfires or anything I pulled over, got out the tuner and checked it. "P1074- Lean fuel condition" quick google search showed that this happens a good bit and that ripp said it was a false code. so kept driving home and that was when I noticed I had less than 3/4 tank of gas. I had just filled up and gone less than 30 miles. Anyone??????
2008 steel blue sahara
with some doo-dads
leman is offline
post #2 of 38 Old 03-17-2015, 12:56 PM
Send a message via AIM to RIPPMODS
Please get a data log recreating the issue, email that file along with last tune written and original backup file to [email protected]. Put a brief description of what you are observing as well as year, make, model.
RIPP
RIPPMODS is offline
post #3 of 38 Old 03-17-2015, 02:17 PM Thread Starter
leman's Avatar
Last 2 I've sent I've never gotten a reply about. But I'll send another one
leman is offline
post #4 of 38 Old 03-23-2015, 12:41 PM
Please PM so I can get personal info.
RIPP
RIPPMODS is offline
post #5 of 38 Old 03-24-2015, 07:50 AM
jerryn's Avatar
hmm.. you have a RIPP supercharger, you are getting around 12mpg. That sounds about right to me. Plus winter gas is crap.. too much ethanol. Look for a gas station that sells lower ethanol. 10% ethanol sucks. not much energy in ethanol.. supercharger will cost more to run. At least in Massachusetts in the winter anyway.
Did you flash your jeep's computer with the latest code from RIPP ?
If you are really running lean you can burn your engine's top end out.
mpg will improve when your fuel rate is right.. not by much
I only know about supercharger overhead from other vehicles I had when I was younger. I never planned on installing one in my 2013 rig.
usually you add more torque on a 4x4 and if you don't upgrade the entire drive train, something breaks. I go off road.. don't want to break an axle
jerryn is offline
post #6 of 38 Old 03-24-2015, 12:00 PM
greenenvey's Avatar
oh I remember that oh so well, pain in the butt to get the imfo and then not receive a reply. or even worse waiting for a new tune finally getting it and is was the excact same tune you already had installed.
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #7 of 38 Old 03-24-2015, 04:02 PM
Guruman's Avatar
I've had pretty good luck when sending in log files. I hope you get an answer soon.
You didn't mention what year. 3.6 or 3.8?
In the mean time start looking for unmetered air getting into the intake or exhaust. Sometimes a small leak on the intake side can cause an actual lean condition, and if it's on the exhaust side, then it will cause a false lean condition. Either way the ECU will pour on the fuel to try to even out the lean condition, causing poor economy.
I'd start there as it sound like you are getting air into it that has not been accounted for by the ECU. Maybe check the dump valve/BOV ? If it's not closing all the way, you might be getting air in that way.
Good luck.
Edit: I see you have an '08....
_
Guruman is online now
post #8 of 38 Old 03-24-2015, 04:38 PM Thread Starter
leman's Avatar
Was getting 18-20mpg hand calculated when it's running right. Normally run 93 octane fuel or 89 no ethanol. And yes I've ran the latest update.
Haha my jeep is ran pretty hard off-road and built to take it...... When the engine is running right
Especially when all the computers in house are macs so I have to go 15 minutes down the road to my parents to do anything.
Good luck.
Double checked exhaust for leaks and have a small one at the manifold but it's been there forever. Even when it was running right. Everything is tight on the intake side too.
with some doo-dads
leman is offline
post #9 of 38 Old 03-25-2015, 06:23 PM Thread Starter
leman's Avatar
Also now it is bouncing back and forth between throwing a code for lean and throwing a code for being rich.
with some doo-dads
leman is offline
post #10 of 38 Old 03-26-2015, 07:45 AM
Guruman's Avatar
You've got an air leak somewhere.
Under boost, some air gets out, causing a rich condition. Under vacuum, some air gets in causing a lean condition.
Did you check the BOV/Dump valve? If it we're stuck open a bit, it could cause exactly the condition you report.
_
post #11 of 38 Old 03-26-2015, 07:50 AM
Guruman's Avatar
Also, since you are getting both a lean and a rich condition. I suspect the problem is on the intake side of the equation, somewhere between the blower and the cylinders.
Make a test cap to properly check for leaks. A tire valve, PVC cap, short connector, a rubber plumbing connector with clamps makes a great way to add air through the blower to pressurize and test everything.
_
post #12 of 38 Old 03-26-2015, 07:55 AM
Guruman's Avatar
Something like this.
_
post #13 of 38 Old 03-26-2015, 10:23 AM
OffRoadGeorge's Avatar
[QUOTE=leman;3225658]Was getting 18-20mpg hand calculated when it's running right.
That is very good millage. I get 12 with 60's and 40's. Wounder if I have a leak or if 11-12 mpg is normal for big JK's?
Silver 4 Door JK
60's / 40's
Ripp
Rebel Off Road Suspension
King Shocks
OffRoadGeorge is offline
post #14 of 38 Old 03-26-2015, 10:31 AM
Guruman's Avatar
[quote=OffRoadGeorge;3230050]
I agree. 18-20 is very good, almost too good to be true. I get maybe 15 on a good day. 3.6, altitude pulley, manual, on 37 MTR's with 4.11 gears.
_
post #15 of 38 Old 03-26-2015, 10:43 AM Thread Starter
leman's Avatar
Headed to lowes now.
[quote=Guruman;3230058]
I'm on 35"s with 5.13s. 95% of my driving is through a state park and county roads doing 55mph.
with some doo-dads
leman is offline
post #16 of 38 Old 03-26-2015, 03:22 PM Thread Starter
leman's Avatar
clamped the seal with a Schrader valve on in place of the air filter. hit it with about 8 psi and it sounds like it is leaking from within the supercharger.
with some doo-dads
leman is offline
post #17 of 38 Old 03-26-2015, 03:40 PM
Guruman's Avatar
I had a fair amount leaking from the union of the intake hat and the blower assembly. This is not usually a concern as it's not normally under pressure.
Check especially the BOV and around the intake. Do the 3.8's have a plastic intake like the 3.6's?
A short piece of rubber hose held up to the ear with one hand and pointing the other around in the engine bay can help find leaks, sort of like a stethoscope.
I still *really* suspect the BOV.
_
post #18 of 38 Old 03-26-2015, 03:45 PM
Fleshharrower's Avatar
I suggest using a mechanics stethoscope, they are under $20 at places like Autozone and do a much better job of pin-pointing noises than putting a tube up to your ear.
2013 JKR - with one of everything.
Fleshharrower is offline
post #19 of 38 Old 03-26-2015, 04:02 PM
Guruman's Avatar
Every mechanic's stethoscope I've seen had a solid rod as the "listening " end. They work well for finding valve clatter, rod slap and squeaking idler pulleys when pressed against the metal parts of the engine, but fell short of finding air leaks. The hose let's me "hunt" for it without pressing it against something solid. I just wave it around in the engine compartment all over and when I hear something, I can "follow" it to the source. YMMV, though.
_
post #20 of 38 Old 03-26-2015, 04:26 PM
Hmm, on my mech stethoscope, you can pull off the metal probe and just use the open hose to listen for vacuum leaks. The benefit over sticking a tube to my ear is that the steth has ear buds the isolate out the rest of local noise.
post #21 of 38 Old 03-26-2015, 04:29 PM Thread Starter
leman's Avatar
Alright good to know. Yes the intake is plastic. Haven't been able to get the system to hold pressure long enough for me to really hunt anywhere. I took the blow off valve off and checked it, and it seemed to be functioning fine. checked the tightness of the throttle body and one of the bolts was a little looser than the rest so maybe i had a small leak there. about to finish buttoning everything up and give her a spin.
still haven't heard back from ripp.
with some doo-dads
leman is offline
post #22 of 38 Old 03-26-2015, 05:45 PM Thread Starter
leman's Avatar
Well I feel like an idiot. So far so good on tightening up the throttle body.
with some doo-dads
leman is offline
post #23 of 38 Old 03-26-2015, 06:23 PM
Nice - it doesn't take much to cause a big problem
post #24 of 38 Old 03-27-2015, 04:07 AM
Guruman's Avatar
Awesome. I hope that's it.
_
post #25 of 38 Old 03-27-2015, 06:27 AM
jerryn's Avatar
Let us know how much more power you have now that the supercharger is working right.
torque ? 0-60 time, horsepower, and did it help with steep climbs up rough terrain ?
Glad it was an easy fix. 18-20mpg That's great mpg with a supercharger. My stock 3.6L gets 16 - 18mpg in the winter.
jerryn is offline
