Thoughts on this hard top hoist setup - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 03-11-2015, 06:38 PM Thread Starter
F.I.D.O.con's Avatar
Any thoughts on this hard top hoist setup?
3/8 x 5" eye bolt in a 2x10. 250lb rating on eye bolt
1/2 ton chain hoist
2 400lb straps around the top to hook to chain hoist.
Chain will be pulled out of the way to protect from scratches as well as wrapping the top with moving blankets. Once lifted I will use a bungee to stop and spinning.
[IMG][/IMG]
[IMG][/IMG]
2015 JKU Rubicon White
3.25" Lift
35" Mickey Thompson MTZ
Fuel Trophy wheels
Ace Pro rear bumper and tire carrier
D44 4.10
ACE C Gussets
Synergy LCA skids
Teraflex axle sleeve
F.I.D.O.con is offline
post #2 of 14 Old 03-11-2015, 07:19 PM
Probably will do the job. I dont doubt the equipment. But I do really hate that its hanging on one eyebolt like that.
WVU Alum.
Coal keeps the lights on and the Jeep parts in the brown truck.
omGoddard is offline
post #3 of 14 Old 03-11-2015, 07:27 PM Thread Starter
I do too but I see plenty of setups with just one eye bolt and a pulley on it. Not sure how to do it differently. I did have a thought of cutting out the sheetrock, drilling a hole through the 2x10 and wrapping a cable around it instead of the eye bolt. But, I was trying not to cut sheetrock.
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
post #4 of 14 Old 03-11-2015, 07:34 PM
OMG!!! Don't use an open eye bolt like that.
At the very least use a closed, welded eye bolt. Have you looked at the replacement cost of a hard top? Don't go cheap on the only thing holding the $$$$$$$ part up.
8000ft is offline
post #5 of 14 Old 03-11-2015, 07:36 PM Thread Starter
I looked for a closed one and couldnt find one. I'm open to suggestions on what to do differently. This is in build/test phase.
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
post #6 of 14 Old 03-11-2015, 07:38 PM Thread Starter
What about a piece of cable wrapped around the 2x10??
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
post #7 of 14 Old 03-11-2015, 08:02 PM
StubEXrube's Avatar
It's all about evenly distributing the weight.
The chains are big-time overkill and combined with only one eye-bolt, are unnecessary.
Best thing is to run 4 eye bolts in line with the overall diameter of the hard-top corners... although that may nor be feasible for your particular application.
You can use ratchet straps or good quality rope ( with at least a 100lb safe working load limit), or a combination of both. I use two ropes and thread them through the front facing mounting holes along the bottom edge of the hard top... and once I get those ropes secured to one set of eye-bolts, I go around back and run a ratchet strap from one eye-bolt- under the rear of the top- and up to the other eye-bolt. It only takes a little muscle to lift up the corners of the hard-top one at a time.
Then you can just drive out and leave the hard-top suspended.
I'm leaving out a lot of details but the way that I have mine set-up it only takes about 10 minutes to remove or to re-install the top ( 2 door).
StubEXrube is offline
post #8 of 14 Old 03-11-2015, 09:41 PM
Comfortably Numb
RubiCajun's Avatar
Way overkill. See post 2.
https://www.jkowners.com/forum/showth...t=door+storage
RubiCajun is offline
post #9 of 14 Old 03-12-2015, 06:56 AM
pizzaman's Avatar
This.
I actually used to have a shed big enough to get the back of the jeep in. I used some old garage door wheel channel (idk what the hell that stuff is called) and bolted it horizontally to the ceiling. then welded a simple square frame together with roughly the same dimensions as the hard top and fitted it into the two channels on the ceiling. Then used ratchet straps (one on each corner), lifted the top just a couple inches. I was then able to just slide it backwards and lower it down without moving the jeep.
probably overkill for what you're looking for, but it was an awesome set up.
pizzaman is offline
post #10 of 14 Old 03-12-2015, 07:55 AM
LepreCon's Avatar
I don't have the ceiling height in my garage that many people so I ran a winch parallel to the ceiling and built a frame similar to the ones I saw for sale.
It works pretty well and my wife can use it with ease. Only bad thing is the rotation after the top is hoisted. Fixed that with bungee cord tension.
LepreCon is offline
post #11 of 14 Old 03-12-2015, 08:18 AM Thread Starter
Thanks for the input folks. So I am going to go find a piece of square tubing like in the above picture. I will secure that with lag bolts to 3 joists/rafters. Then get a full circle eye bolt and bolt that to the square tubing. Will this be enough?
I have seen quite a few write ups with people just using 1 eye bolt (open like mine) and a pulley, then another open eye bolt over by a wall with some rope and a hand crank winch. So I thought for sure my set up would be sufficient.
I have 20ft ceilings in my garage but my ceiling space is limited so a single rope/chain setup like mine is pretty much what I am limited to from what I can see. Thanks for everyone's help.
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
post #12 of 14 Old 03-12-2015, 08:37 AM
StubEXrube's Avatar
Although I don't personally care for the thought of one piece of hardware suspending the entire top, that does sound like a better plan than your first idea.
Another reason that I prefer distributing the load is not only because it lessens the stress on the hardware, brackets, ropes, straps, etc... but is also so that stress on the hard-top itself is minimized. Make sure that when you hoist it up, that you aren't causing undue amount of flex or strain on any one location of the hard-top. Stress fractures, fatigue, and warping isn't always immediately visible so just make sure that if you need to make adjustments or possibly use some foam or rubber padding to minimize these hazards, that you do so.
Hard-tops are expensive to replace so just make damned sure that everything is secure and able to safely suspend the top for an extended amount of time.
post #13 of 14 Old 03-12-2015, 09:09 AM Thread Starter
Where did you buy that square tubing?
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
post #14 of 14 Old 03-12-2015, 09:12 AM Thread Starter
The pictures are just how it attaches to my ceiling in the garage. I am going to use ratchet straps to connect the hard top to the hoist. I have seen countless write ups of people doing the same thing. Looping two ratchet straps through the hard top and hoisting it up. Or I may build a hard top contraption like in the pictures above using the square tubing.
3.25" Lift
Fuel Trophy wheels
D44 4.10
ACE C Gussets
Synergy LCA skids
