MB72s - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 03-06-2015, 01:44 PM Thread Starter
MB72s
Hi, I am about to buy 15 inch MB72s for my 2008 JK Wrangler. I was told that most likely they would rub with my calipers... is that true? any help is appreciated. thanks! i'll be putting a 4 inch rough country lift before I run them though.
jk2008fig is offline
post #2 of 13 Old 03-06-2015, 01:50 PM
terrahawk's Avatar
Lift won't improve caliper clearance.
You need to do some research: http://www.upgrademotoring.com/faq/wheel_terms.htm
terrahawk is offline
post #3 of 13 Old 03-06-2015, 01:53 PM
I ran 15 x 8 MB Chaos on mine with 3.75 backspacing and had no issues
stretch79 is offline
post #4 of 13 Old 03-06-2015, 02:02 PM Thread Starter
Thanks that was actually helpful...
I guess I can see where the other guy thought I meant the lift would have anything to do with the caliper situation... thought I put that I was going to run 33 BFGs with them...
post #5 of 13 Old 03-06-2015, 02:03 PM
If you go to discounttiredirect.com and call the # they will tell you which 15s will fit and which wont.
You will need to strategically place the wheel weights...or they will hit the caliper. The actual wheel was about 1/4" away from the caliper.
post #6 of 13 Old 03-06-2015, 02:04 PM Thread Starter
awesome man thanks!
post #7 of 13 Old 03-06-2015, 02:07 PM
MB tires should fit fine. I have MB11 and they work great with my 35x15x12.5 tires... plenty of clearance and they look great. Very similar to Methods NV
Danilo is offline
post #8 of 13 Old 03-19-2015, 09:41 PM
Gojo03's Avatar
I have 35s mounted on 15" MB72s now. I have ran them for a couple years with no problem. The only issue I ever had was when balancing, they have to use clip weights on the inside lip of the rim instead of the weight tape.
Gojo03 is offline
post #9 of 13 Old 03-19-2015, 09:48 PM
Fleshharrower's Avatar
Gojo03, what back spacing do your 15" MBs have?
2013 JKR - with one of everything.
Fleshharrower is offline
post #10 of 13 Old 03-20-2015, 12:11 AM
Gojo03's Avatar
3.75" I believe
Gojo03 is offline
post #11 of 13 Old 03-20-2015, 01:23 AM
UnlimiDozer's Avatar
I realize this is not the point of this thread, so technically it is a hijack but it's a minor one and it's good information for posterity . . .
Good luck finding Black MB72s in a 17" anymore. Not sure why, but they discontinued them some time ago.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #12 of 13 Old 03-20-2015, 07:34 AM
sixstring's Avatar
I run 15x8 3.75 BS with no issues other than the tire shop double stacking weight tape. My calipers quickly resolved the issue.
sixstring is offline
post #13 of 13 Old 03-20-2015, 07:35 AM
Victim Of Pain's Avatar
OP wants 15's. Not sure why everyone is worried about grinding the calipers. Took 2 minutes and have created zero issues. Find a wheel you like and go with it, if you have to grind, then grind away.
Victim Of Pain is offline
