8000 pound winch - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 02-05-2010, 02:46 PM Thread Starter
djkbooth's Avatar
Question 8000 pound winch
Hi there guys how is everyone?
Is an 8000 lber mounted on a smittybilt src bump okay for a 2010 4 door rubicon w/ 4 inch rough country with 35/1250/17s, non extreme wheeling mostly trails and sloppy stuff?
Will it be enough?
djkbooth is offline
post #2 of 10 Old 02-05-2010, 02:50 PM
TheBeatenPath's Avatar
not sure i dont own a winch... yet
but i know snatch blocks double the pulling power so it might be possible i ll leave it to others with winches tho
TheBeatenPath is offline
post #3 of 10 Old 02-05-2010, 03:02 PM
FlameRed's Avatar
you should be fine. An 8000 lbs winch, such as the Warn M8000 for example, will still pull 6200 lbs on it's 4th wrap. If your JK weights 5K then you are not exceeding the capacity. A 8K winch will be a little faster and pull more amps than a 9.5K winch would on the same pull becuase it will probably have less gearing.
It's always good to carry a snatch block for those hard pulls though...
2009 Rubicon Unlimited, FLAME RED
37's on WE beadlocks. ProRock44 w/ARB, RCVs, spyntecs, PSC hydro assist. Rear D44 w/35 spline ARB. 4.5" Poly/TF lift.
FlameRed is offline
post #4 of 10 Old 02-05-2010, 03:02 PM
Northernmedic's Avatar
Yes and no. An unlimited is very heavy, the larger the tire the more rolling resistance is encountered. This will push an 8000lbs winch to it's limits. A snatch block does help but, don't forget that you are also decreasing the line lengh by half. Better hope you're stuck close to a tree or where someone can get close. Anyway you look at it you're spending hard earned money on a piece of equipment that you will rely on to get you home. Why waste money on a winch that may or may not work.
Northernmedic is offline
post #5 of 10 Old 02-05-2010, 03:15 PM
SONIC's Avatar
I'v been running an 8k for about a year now. A few good pulls with no problems at all.
Deep mud mostly.
But, I just got a XD9000i so.......
-Doc Holiday
SONIC is offline
post #6 of 10 Old 02-05-2010, 03:32 PM
I have a warn 8000, it has pulled me out of several situations. Usually the winch is only needed as a boost to get you out of a situation. You will be fine, a snatch block is good insurance if you need to double your pull.
w.wood jeepster is offline
post #7 of 10 Old 02-05-2010, 03:41 PM
fl-mitchells's Avatar
I'm using an 8500lb Superwinch and have had several difficult pulls, the winch did fine. It's slow as molasses though.
"Experience is something you don't get until just after you need it." --Stephen Wright
fl-mitchells is offline
post #8 of 10 Old 02-05-2010, 03:41 PM
Comfortably Numb
RubiCajun's Avatar
I run a Superwinch EPI9.0. It came with a snatch block and external control. A wireless control is available. It also came with 125 feet of cable. This and the fact that it has the lowest amperage draw of comparable winches led me to purchase it. It has worked flawlessly. It was also the least expensive of the comparable winches at the time. Checkout the superwinch site for the comparison chart. Yeah you could get away with an eight. But you could need something bigger depending on how technical your winching situation is. I got mine from 4X4 Rockshop.com. good luck.
RubiCajun is offline
post #9 of 10 Old 02-05-2010, 06:04 PM
ZOSO-Green's Avatar
Look, an 8k winch will work just fine as long as you are smart about it.
You can buy a snatch block and a nice 30ft tree hugger strap and you
will double your pull. Just keep in mind that its a self recovery winch.
Don't be a hero unless its the only option.
ZOSO-Green is offline
post #10 of 10 Old 02-06-2010, 07:49 AM Thread Starter
djkbooth's Avatar
thanks for the replies
djkbooth is offline
