Convert PS Body Mount Rocker Knocker to Frame Mount? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 11-04-2014, 10:58 AM Thread Starter
maniacal_rick's Avatar
I have the Poison Spyder body mount Rocker Knockers on my 2012 2 door and unfortunatly they havent held up very well. After one or two "knocks" the passenger rocker has bent up and now contacts the door preventing it from opening. I contated PS about this and thier response was there was nothing I could do and to purchase the Passenger rocker again, which of course they would sell me at a (slightly) reduced cost.
I get they are technically wear items and I am not debating that they did their job in protecting the tub, but at $600 for the set they are a damn expensive wear item and I personally dont feel I got my moneys worth out of the body mount sliders.
So, being that the actual slider frame is the same on both the frame and body mount has anyone tried converting? I contacted PS about buying some of the frame mounts and they said no, and once again suggested that I purchase another set of sliders. So, $600 and 2 wheeling trips later I am on my own.
So has anyone tried this? I dont believe it would be very difficult to grind off the body mounts and weld on frame mounts...or should I scrap the entire idea and buy new sliders from a different vendor?
maniacal_rick is offline
post #2 of 7 Old 11-05-2014, 05:20 AM Thread Starter
Bump
post #3 of 7 Old 11-05-2014, 08:43 AM
TCdawg's Avatar
I had this same problem with my Rocker Knockers. Bent the passenger side up and the door contacted it on open and close.
I fixed mine by bending it back...no easy feat as the things are stout, lots of chains and hydrolic presses. When we were bending it back, we discussed a solution of cutting off all the lower tub mount parts and welding it to the frame with tube and plate. In the end, that amount of work was just not worth the money and it would make taking the skin off almost impossible for refinsihing or replacement if damages.
My permanent solution was swaping out to VKS weld on sliders. Very solid...should not be having the issue of bending up in to the door again.
TC
TCdawg is offline
post #4 of 7 Old 11-05-2014, 06:42 PM Thread Starter
That's my second option. I like the VKS as they look super stout, but I like the look of the PS more. I don't have the equipment to try and bend these back but I can cut and weld. I guess I was trying to get more use out of these before I scrap em'.
post #5 of 7 Old 11-05-2014, 06:58 PM
TCdawg's Avatar
If you can do the cutting and welding, not a bad idea to move them to frame mount. Post up your end result.
TC
TCdawg is offline
post #6 of 7 Old 11-06-2014, 08:58 AM Thread Starter
If and when i do, I will post up here. I need to search some of the vendors to see if they offer mounts that I can use instead of fabbing my own.
post #7 of 7 Old 11-06-2014, 09:04 AM
TCdawg's Avatar
Hit up VKS and see if they will sell you their plate, tube and gussetts that they use on their weld on sliders. Seems like the perfect pieces.
TC
TCdawg is offline
