Rear seat heaters - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 11-03-2014, 07:10 PM Thread Starter
Rear seat heaters
I installed seat heaters in my front seat last year and really like having them. The kids sit in back and I kind of like them, so I was considering putting the same in the rear seat (2011 JKU by the way).
Searching... has anyone done this?
Looking at the rear seats, the bottom looks like the fabric comes loose just like the fronts, with clips on the front edge you can unclip, then slip the heater element in But the backs appear completely stitched up.
Is my assessment correct or is there a secret way to get them off outside of ripping out stitches and restitching it?
'11 JK Unlimited Sahara - 2.5 Frankenlift, ,33X12.50 Duratracs on 15" MB72s, Genright Rockers (aluminum), WURX front and rear bumpers/tire carrier, Warn winch
'01 TJ 60th Anniversary, 2" Budget Boost, 33" BFG ATs, AFW Front Bumper, Olympic Rock Bumper, Warn Engine & Steering box skid, Kilby Gas Tank Skid, OR Fab Rock Slider Bars, Rhino'd tub - GONE
murfysflaw is offline
post #2 of 9 Old 11-04-2014, 11:29 AM
tcodjk's Avatar
I installed heaters in the rear a couple of years ago. I didnt even remove the seats.Cover are pretty much the ame as the fronts.
07 unlimited LS 6.2 6l80 auto 3" black diamond 37" TOYO MT Trailready beadlocks arb's frt & rear
tcodjk is offline
post #3 of 9 Old 11-04-2014, 11:52 AM Thread Starter
Interesting. I felt around across the bottom of the seatback and didn't feel the same attachment as on the seatback on the front. I wonder if it's different between our year models...
post #4 of 9 Old 11-05-2014, 06:48 AM
tcodjk's Avatar
It seems to me that the backs on mine were zippers. The end of them were folded back and tucked in.
tcodjk is offline
post #5 of 9 Old 11-05-2014, 09:27 AM
Dutchboy101's Avatar
I installed my rear seat warmers about 4-5 years ago, when I installed my Katzkins. Wasn't a difficult project, I bought the same ones I installed in the front seats, the wiring was just long enough.
Dutchboy101 is offline
post #6 of 9 Old 11-05-2014, 09:49 AM Thread Starter
Thanks. I didn't get a chance to check last night, but I'm going to dig into it tonight and see if I can confirm. If it's a zipper, it will be amazingly simple. Hardest part will be finding the best power source since the accessory outlet is 20A... I don't mind having the front two on that since they are 4A each on high, and the only other thing I plug in there is my cell. But if all 4 are on high, it would potentially overload.
May just feed it from my dbox (once i install it).
post #7 of 9 Old 11-05-2014, 07:50 PM Thread Starter
Ok... I checked closer and it's not as obvious as the fronts. There are small zippers on the corners, but they are kind of reversed, so it doesn't look quite like a zipper when you glance.
Also. across the back, at the very bottom, but not underneath, it is at the bottom of the back... feels like a piece of cardboard, but it's really a plastic lip that's folder over under the fabric and back into another channel where it locks. Hard to explain, but I'll get pictures when I actually remove them to install the heaters.
post #8 of 9 Old 11-07-2014, 06:50 AM
tcodjk's Avatar
Its really not hard to install the heaters without pulling the seats.
tcodjk is offline
post #9 of 9 Old 11-07-2014, 08:06 AM Thread Starter
Sorry... yes, the rears definitely look easy w/o removing. Having done 2 sets of fronts, I'd still remove those although it could be done w/o. Mainly because of the difficulty getting the seat back cover reconnected... it takes work and manuevering even out of the vehicle... not sure I can twist my body the right ways to do it inside.
