adding heated seats to a 2014 - pressure sensor on passenger side?
so i read on one of the other forums that because of some pressure sensor, adding heated seats to a 2013 and up jk isn't possible for the passenger side. is this true? All of the Mopar kits cut off at 2012 which seems to confirm this.
anyone added them to a 2013 or newer JK? Mopar or aftermarket? I'd like to stick to Mopar, but also considering the warmseats weatheproof ones. i added Mopar ones to an older JK in the past, but there wasnt the concern of the pressure switch.
Sponsored Links | |||
Advertisement |
I bought mine from amazon for like bucks. Then bought trek armor seat covers. I put the heaters between the seat and the seat covers and it warms so much better. They are on a switch and you can control hi and lo settings. About 10 minutes on high and I have to turn it off.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Advertisement |
Originally Posted by nlgrav182
View Post
Why couldn't you use the power/signal from that pressure sensor to trip the relay to allow the heated seats to work? I don't get what one would have to do with the other.
Originally Posted by Uncle Sams Misguided Child
View Post
I would not go cutting into the seat weight sensor. It is there for the airbag system and can lead to bad things happening if you swap the load on the circuit. BMW used to run the belt tensioners stages with the air bags. a tech was screwing around under a seat and hit something setting it off. the thing is basically a 12 gauge shell with no shot in it. I have not seen them on Jeeps but that weight sensor is a vital part of the air bag system.
Let me know if you need help with it. Basically it is just hooking up the wiring to a positive and negative. It has all the wires and relays included. I did have to lengthen the lead wires though and tuck all the damn wiring under the center console. But the switches are mounted right above and to the right of the parking brake.
Originally Posted by pizzaman
View Post
2. Yes. see here; https://www.jkowners.com/forum/showthread.php?t=139801
View Post
2014 Rubicon Unlimited with Sponge Bob Squarepants Floor Mats.
Get your FREE college education here
Originally Posted by soonerfan85
View Post
Are they THAT different from the OEM heated seats for the 2013 and 2014 models?
Edit: Quadratec does have these http://www.quadratec.com/products/14159_1003.htm
Edit #2: so the link above shows 3 heating elements....2 for the driver and one for the passenger. i spoke with a quadratec rep and asked about this and he confirmed that it's because of the airbag sensor. the passenger side only gets the back element, not the bottom.
Thought that the interior stayed the same from 2011-2015? Am I correct in thinking this???
"Government is not the solution, it is the problem."
"We are never defeated unless we give up on GOD."
"Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be protected, and handed on for them to do the same."
Ronald Reagan
Life is 10 percent what happens to you and 90 percent how you respond.
The seats are different. I did my seats on my 2012 without any problems but when doing my brother's 14 the seat design changed which we still were able to make it work.
Originally Posted by redbank
View Post
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
