Power windows. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 11-02-2014, 11:40 AM Thread Starter
Power windows.
I just bought my first jeep (an '08 4 door Unlimited) and I have fixed most of the things that I have found wrong.
One thing that has thrown me a little are the back windows. Neither will roll down with any switch. The front works fine but not the back.
Any ideas where to start looking? If I had a wiring diagram I could probably go straight to it.
Thanks,
BugMan70
Bugman70 is offline
post #2 of 9 Old 11-02-2014, 03:57 PM
Check the quick disconnect plugs they always seem to be a problem once you start removing the doors.
CT Performance, Inc is online now
post #3 of 9 Old 11-02-2014, 05:57 PM
JKO Dickhead
Asmmns's Avatar
power door locks ??
if the harness if disconnected the rear locks wont work either .
__________________
CURE SMA !
Asmmns is offline
post #4 of 9 Old 11-02-2014, 06:55 PM
jacktuttle's Avatar
Lightbulb Motors
The front and rear motors are the same. You can try swapping a window motor from the front to the rear and know if its the motors or something else.
jacktuttle is offline
post #5 of 9 Old 11-02-2014, 07:10 PM
MoTech's Avatar
Under the console is the connector for the rear windows, it's a pain to plug in so I've seen several left unplugged. Remove all 4 bolts holding down console and yank up on parking brake. Lift rear of console and check the rear windows are plugged in.
MoTech
725-502-8507
MoTech is offline
post #6 of 9 Old 11-02-2014, 07:11 PM
KevinJBurt's Avatar
Send a message via Yahoo to KevinJBurt
Like Asmmns said, try the door locks if those don't work either you know the problem is outside the door, which would be better. It'd be pretty weird to have the rear window motors go out before the front...
Always forward never straight sometimes upside-down!
KevinJBurt is offline
post #7 of 9 Old 11-04-2014, 12:11 PM Thread Starter
MoTech,
You couldn't be more correct. It was a bear to hookup.
I just have to ask what kinda shop does this?
They put a brake cable on this Jeep before I bought it and it may have been disconnected then. I'm sure they tried to fix it cheap.
Thanks again,
Bugman70
Bugman70 is offline
post #8 of 9 Old 11-04-2014, 12:52 PM
KevinJBurt's Avatar
Holy crap why would anyone unplug those in the first place??
post #9 of 9 Old 11-04-2014, 06:00 PM
they unplugged it to get the console out to swap parking brake cables. I did the entire parking brake system and rear brake system on my 07 about 3 months before I decided to trade it in.
Tspevacek is offline
