AEV lift help, handling issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 54 Old 10-30-2014, 10:04 AM Thread Starter
holiday13's Avatar
OK, my JKU is a glorified mall cruiser/beach runner, sees no offroad (don't really consider the beach offroad) so I elected to go with the 2.5AEV lift over others. I installed the lift with their control arm drop brackets and a JKS front trac bar.
After the install the Jeep handled awful, almost undrivable. After some research we found I had been sent 2 door springs for my 4door, got that squared away with new 4 door springs and now is handling slightly better, on flat pavement. When I drive on any type of uneven road or hit the slightest bump the whole jeep rocks and sways violently. I have triple checked the install and I did it right, have had 2 alignments and it is dead on.
My question here is could the use of the soft 2 door springs (which were in the jeep for maybe 3,000 miles) have overly tweaked my sway bars where it has lost its strength/rigidity? Could the soft springs have blown the shocks out? What else could I be missing here? It feels as though the sway in the jeep begins/originates in the rear end but it may just be translating to the rear from the front.
For reference I have owned many jeeps over the year, I had a TJ on 37's that handled far better then this jeep is right now, that TJ I had no issues running high speeds down the road, this JKU right now my wife won't drive and doesn't even like getting into as a passenger.
Any ideas/suggestions would he hugely helpful at this point. Thanks!
2012 JKU Sahara, basically stock
1989 4Runner, SAS, ARBs, 35's, yada yada yada
1998 Tj 1ton build in progress, stretch to LJ dimensions, chevy v8 (350+hp), auto, duals, 1tons, 40's, coilovers, the usual family wheeler
Former Team Quadratec driver #831
holiday13 is offline
post #2 of 54 Old 10-30-2014, 10:23 AM
can't tell if this is a real post or not.... No to all the questions. Check it all again but in a different order.
2013 JKU Sport, RE 2" w/Bilsteins 5100, 315/75/16 Toyo Open country on stock wheels 1.5" spacers, AFE intake and 3in Cat-Back SS-409 Exhaust Systems, superchips flashpaq, AEV front CA drop brakets, EVO rear rock star skid/shock lift, trek armor seat covers/seat heaters, spiderwebshade, truck lite LED's.
Handful of cream is offline
post #3 of 54 Old 10-30-2014, 10:27 AM
SoK66's Avatar
Pics of the install might help. We put one on a club member's '10 JKUR last year and it rides & handles better than stock. Assuming you got all the right parts on it now, need to reinspect the installation.
SoK66 is offline
post #4 of 54 Old 10-30-2014, 10:59 AM
Tat2dfreak's Avatar
I have install a bunch if those kits with no problems. Sounds like something was not install right.
Pics might help.
Tat2dfreak is offline
post #5 of 54 Old 10-30-2014, 12:09 PM
kjeeper10's Avatar
Def something wrong. Did you or installer loosen all CA/TB Bolts and tighten at ride height ?
Same tires ?
kjeeper10 is offline
post #6 of 54 Old 10-30-2014, 12:17 PM Thread Starter
holiday13's Avatar
I will try and get pictures tonight. I installed the kit myself to AEV's instructions to a T. Probably won't have pics until the weekend though due to the rapidly fading light.
Tires are the same, I had a 2" RE spacer lift on first and was trying for a better ride and a hair more height, sadly ride is much worse now with the AEV kit.
post #7 of 54 Old 10-30-2014, 12:33 PM
boopiejones's Avatar
i've got that same lift and agree that it handles better than stock. for what its worth, i was originally sent 2 door springs instead of 4 door as well. luckily it was noticed before the installation.
regardless, i don't think installing the 2 door springs on a 4 door would cause problems. if anything, you would just have a reduced lift height and maybe slightly more plush ride due to a softer spring rate.
boopiejones is offline
post #8 of 54 Old 10-30-2014, 12:41 PM
White13JKUR's Avatar
so what does "handled awful" mean? Too much body roll? Not soaking up the bumps. vague steering? Pulling? Overstear? Understear? What tire size and pressure? What exactly does awful handling mean?
I've had both the aev 3.5" and 4.5" on my 4 door as well as run it with and without the granite shaving brackets. It handles very well on the road (as advertised) and I have no problem throwing that jeep through a corner on 37s just like I do with my tuned E46.
Who's up for a jeep day at sears point? Im in.
edit: Yes. the AEV lift DOES handle better than stock. It was night and day IMHO.
White13JKUR is offline
post #9 of 54 Old 10-30-2014, 01:09 PM Thread Starter
holiday13's Avatar
Sorry, I will try and explain as best I can. The jeep gets excessive body roll in corners to start, far more than when it was stock to the point I actually take corners quite a bit slower, definitely do not even consider "throwing" it around in corners. If I hit a pot hole or bump in the road (I live in a rural area, and yes NJ has rural areas) you can feel the whole jeep sway, almost feels like the sway starts in the back passenger corner and translates to the front. Sadly I can do this at will on my way home from work each night. It honestly feels as though there are no sway bar in the rear of the jeep at all but yes it is there and is hooked up.
I am running 295x70x18 Nitto Terra ATs on 18x8.5 rims and I have tried running pressure anywhere from 30-40PSI with no real change (40 just a harsher ride on bumpy roads which is to be expected). I generally run 30-32PSI.
post #10 of 54 Old 10-30-2014, 03:22 PM
I have that lift and it handles perfectly especially in corners. Something's missing! Sounds like sway / trac bar issue? We have a 2 door & a 4 door and they both corner very well.
scubatech is offline
post #11 of 54 Old 10-30-2014, 03:36 PM
Dollar's Avatar
I just installed that lift on my neighbor's 2015 (last weekend). Are you sure you torqued everything down with the Jeep on the ground? Sway bar links reattached?
You said you followed the install to a T. The instructions fail to mention to reattach the front track bar axle side bolt. It tells you to remove the axle side bolt and loosen the frame side, but never literally tells you to put it back together.
http://www.aev-conversions.com/ishee...EV30207AD).pdf
Not saying you forgot, just trying to help.
Dollar is offline
post #12 of 54 Old 10-30-2014, 05:54 PM
Trail Concepts Hmfic
jdemonto's Avatar
I only heard one other guy say this about an AEV kit and thats exactly what happened!
Whats the PSI in the tires? Should be at 28-30 Cold and loosen and re-torque control arms on the ground not in the air.
Jason
602-314-5356 or
jdemonto is offline
post #13 of 54 Old 10-30-2014, 07:23 PM
Second the suggestion to check torque on everything. If you didn't already do it, loosen and retorque the front control arm bolts you touched when installing the drop brackets.
Body roll should be a little less less than stock because aev puts progressive springs up front. On my rubicon, stock springs were progressive in the back and linear in the front. Swapping out just the front AEV progressive springs for EVO plush ride linear springs of the same height might return the stock driving feel. I was thinking about playing around with this approach myself having read that others did it.
post #14 of 54 Old 11-12-2014, 02:13 PM Thread Starter
holiday13's Avatar
Sorry for the delay, finally weather and time allowed to go and try what was suggested above, loosen and re-torque everything. Did that last night and no luck, just as bad as before. Tried uploading pics but I have to re-size as they came in too large, will get them posted later. At this point I am ready to rip this lift out and try something new. Does anyone know the part numbers I should be using for the correct JKU springs?
post #15 of 54 Old 11-12-2014, 02:27 PM
Have you tried a different set of wheels/tires that are known to ride correctly? May sound like BS but I had a set of toyos that would grab every single spot in the road and whip you around like crazy. Took them off and problem went away. Grant it they were almost bald and E rated, now running almost new KM2 C rated but still worth a try for you and doesnt cost you anything except time.
Got any pics of your drag link/track bar? Maybe something in the geometry is off or hooked up wrong and someone could spot it. Did you put your sway bar links on correctly, I only ask because my buddy did his backwards on the back...won't mention his name.
Any chance your front sway bar is disconnected?
stretch79 is offline
post #16 of 54 Old 11-12-2014, 02:48 PM
kjeeper10's Avatar
What hole in the brackets are you running ?
Possibly a bad shock(s)?
Very uncommon for people to be having issues with the AEV 2.5
post #17 of 54 Old 11-12-2014, 02:48 PM Thread Starter
holiday13's Avatar
Thanks for the reply, sadly no access to different tires and wheels so that is out.
Front sway bars are definitely hooked up, checked that again last night.
Here are some shots (sorry for the water spots, living on a partially dirt road makes keeping clean this time of year tough).
post #18 of 54 Old 11-12-2014, 02:51 PM Thread Starter
holiday13's Avatar
Top hole in the drop brackets. Really wondering if the shocks blew out from too much load when the wrong springs were in, too soft a spring making the shocks work too hard.
post #19 of 54 Old 11-12-2014, 02:57 PM
kjeeper10's Avatar
Disconnect the lower bolt and cycle each shock. Worth a check.
post #20 of 54 Old 11-12-2014, 02:58 PM
kjeeper10's Avatar
Your rear sway bar is pointed to the ground?
post #21 of 54 Old 11-12-2014, 03:02 PM
Robnoxious1's Avatar
Are you sure you got the steering wheel perfectly centered? The ESC will make your vehicle drive like its freaking possessed if its not spot on.
Robnoxious1 is offline
post #22 of 54 Old 11-12-2014, 03:16 PM
also looks like a heck of a gap between the rear bump stop pad and the bump stop. maybe he got 3.5" springs this time around or it is not actually on the ground. might just be an optical illusion too.
Jadmt is offline
post #23 of 54 Old 11-12-2014, 03:33 PM
Fklein6768's Avatar
Ill be in flemington tomorrow and am somewhat local if u want to swap rims and tires to see if that makes a difference for you or just a fresh set of eyes. And would also check the shocks like others have suggested. Have a set of poly 3" springs laying in the garage with some jersey road grime on em too if u want em.
www.4x4s-pod.com
Fklein6768 is offline
post #24 of 54 Old 11-12-2014, 03:46 PM
Why does your rear trackbar have the bend close to the axle side? Not sure if that would make a difference or not though, hopefully someone else has an opinion on that. I don't recall mine being bent at that point, seems like mine is straight, but mine is also a 2014 so maybe model year differences.
post #25 of 54 Old 11-12-2014, 03:48 PM
kjeeper10's Avatar
Hmm .. Op
From my experience with installing 2 AEV 2.5" lifts, there was rake still present.
How high is the rear in relation to the front?
