Transmisison & Temp Warning after installing 33's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 10-05-2014, 10:02 PM Thread Starter
BryGuy's Avatar
Check Engine & Temp Warning after installing 33's
I just installed a set of 285/75R16's and after 150km's my temp warning light came on (gauge was at half way point) and a few mins later my Check Engine light came on, followed a short time later by warning binging every 30secs.
My 2008 only has about 40k on it and I've never had either problem before.
Not sure if this is a cause of the larger tires or a coincidence.
Any help to diagnose/solve the issue would be greatly appreciated.
2008 JK X 2dr. Std. Blk
BryGuy is offline
post #2 of 7 Old 10-06-2014, 06:22 AM
Were you out wheeling or on the street?
post #3 of 7 Old 10-06-2014, 06:58 AM Thread Starter
BryGuy's Avatar
Street.
BryGuy is offline
post #4 of 7 Old 10-06-2014, 08:06 AM
The engine light came on?
Did you check fluid level in Trans?
post #5 of 7 Old 10-06-2014, 08:57 AM Thread Starter
BryGuy's Avatar
I'm a tool... I said transmission light and I meant check engine light... orig post/title changed.
This is what occurred: I was on the highway and the idiot light next to the temp gauge came on for 5secs and turned off. It did this a bunch of times over a 10min period. The temp gauge never passed the halfway mark. After that 10min mark the check engine light came on and started and there was also a audible binging warning every 30secs or so that started during the last 1km of my drive.
FYI - 6spd Trans.
BryGuy is offline
post #6 of 7 Old 10-06-2014, 02:17 PM
ronjenx's Avatar
FYI - 6spd Trans.
I'm glad I waited to respond. I'd have been way off on that one.
So, which light next to the temp gauge lit up?
The one to the upper right? Or, the one to the upper left?
ronjenx is offline
post #7 of 7 Old 10-06-2014, 07:49 PM Thread Starter
BryGuy's Avatar
I'm pretty sure it was the upper right.
so I googled JK warning lights and ended up doing the key on/off thing to get the DTC trouble code which was P0157 - O2 Sensor 2/2 Circuit Low.
BryGuy is offline
