tire pressure Nitto 33's trail grappler - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 09-29-2014, 06:30 AM Thread Starter
I have a 2 door 08, on the tire it says 80 PSI Max, I just put them up to 65 PSI, What are yall running in them. I do a lot of HWY miles.
capt surf is offline
post #2 of 9 Old 09-29-2014, 06:53 AM
JeeperJK's Avatar
WOW! That thing has to ride like a lumber wagon at that pressure. I am running my 35" Toyos right around 30psi.
I would imagine you have to be running right in the center of the tread. Have you noticed if the jeep is darty now?
JeeperJK is offline
post #3 of 9 Old 09-29-2014, 07:01 AM
2Door's Avatar
Holy sweet mother of god. The number on the sidewall isn't the recommended pressure, that's the MAX pressure. I run my Mickey Thompson tires at 32 psi.
That said, your tires should be around 30, probably. Best way to figure out what your pressure should be for optimal tire wear is to grab a piece of sidewalk chalk, draw a line across the front tires and make a couple of revolutions. If the chalk wears in the middle, the tires are over inflated. If the chalk wears on the sides, it's under inflated. Keep experimenting until you have an even wear across the entire tread block of the tire.
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #4 of 9 Old 09-29-2014, 07:02 AM Thread Starter
I have not noticed but have not got over 35 MPH yet. I think I am going to drop them back down to 40. I am leaving tomorrow on a 400 mile road trip.
post #5 of 9 Old 09-29-2014, 07:04 AM Thread Starter
The max on my sidewall is 80PSI
post #6 of 9 Old 09-29-2014, 07:10 AM
wildchild's Avatar
32 PSI on my BFG AT's
wildchild is offline
post #7 of 9 Old 09-30-2014, 04:04 AM
2Door's Avatar
Even 40 is too high. Do the chalk test. You'll probably be around 32.
2Door is offline
post #8 of 9 Old 10-01-2014, 12:56 PM
MrBreeze's Avatar
Location: Cave Creek, AZ to Fayetteville, AR, back to Scottsdale, AZ
I run 28 psi in my Nitto Trail Grappler 35's
Chalk tested.
MrBreeze is offline
post #9 of 9 Old 10-09-2014, 06:14 PM
g i joe's Avatar
I'm not running the same tire as you, but when I installed Cooper Discovery STT's on mine about 45k miles ago, I chalked mine and am running 25 psi in them. I check the tread depth every 5k miles when i rotate them and they are wearing perfectly flat across the width of the tread. Every tire may be different, and would recommend the chalk test as mentioned previously.
Joe
The original point and click interface was a Colt.
Only two defining forces have ever offered to die for you... the AMERICAN SOLDIER and JESUS CHRIST. One died for your freedom; the other for your soul.
g i joe is offline
