Differential temps after driving? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-27-2014, 09:03 AM Thread Starter
membrain's Avatar
2014 JKURX manual transmission with 4:10 gearing and 37" tires.
Paranoia or valid issue:
Got out and crawled underneath to do an impromptu check and just noted that my front differential is much cooler than my rear differential... I had just completed a 25 minute drive across town in 2WD.
... Still have the drive shaft connected on the front so the drive train still turns parasitically to the transfer case... I just don't ever remember the rear diff being hotter than the front.
The front was warm to the touch while the rear was actually hot enough to not allow me to keep my hand on the casing.
Can anyone else make a quick check of their differential temps after a trip and let me know what they find?
Thoughts:
Rear diff seal appears ragged... I wonder if I have lost oil from it?
Have not hit the rear diff on anything
Have not pulled the rear diff cover for any reason (yet!)
What should the oil level for the rear diff be measured at? (Gonna go check when I know what I'm looking for)
2010 Red Unlimited Rubicon 6 speed - Traded!
2014 Red Unlimited Rubicon X 6 speed - starting over!
membrain is offline
post #2 of 3 Old 09-27-2014, 04:04 PM
UnlimiDozer's Avatar
Thoughts:
It's normal. More heat buildup in the rear because it's actually under load instead of coasting. If you're concerned, get yourself a cheap laser thermometer at Harbor Freight or somewhere and monitor them regularly. Be prepared to see the temps go up significantly if you swap gears, tow, etc.
By "rear diff seal" I'm assuming you mean the silicone sealing the cover to the housing. Probably just what oozed out as the cover was tightened unless you can see evidence of significant leakage.
Rear diff oil should be at least up to the level of the bottom of the housing tubes so you can get lube out to the wheel bearings at the end of the tubes. If you haven't lifted it -- i.e. Changed the rotational angle of the diff housing -- you should be able to pull the fill plug on level ground and feel the oil with the tip of your little finger at the bottom of the fill hole.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #3 of 3 Old 09-28-2014, 07:21 PM Thread Starter
membrain's Avatar
Thanks, thought I was getting old or something.
membrain is offline
