Is this a problem? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 01-20-2010, 07:00 PM Thread Starter
jkmorrow's Avatar
Is this a problem?
Okay heres the deal, I noticed a oil stain under the Jeep about two weeks ago and the only thing I saw that could be leaking was the front diff cover. I went to work and check under later in the day and found no stain on the pavement. Two days later the stain was back. The only thing I can think of is when I drive on the freeway,75+ mph for about 20 miles it leaks. If I drive around town it don't. Any input? I only have 10,000 miles on it.
2009 Silver Sahara Unlimited
4" RC
35x17 BFG M/T KM's
17x8 Black Rock VIPERS - Black
Superchip Flashpaq
Smittybilt SRC Rear bumper and Tire carrier
"Grey Ghost"
jkmorrow is offline
post #2 of 13 Old 01-20-2010, 07:06 PM
bodyguy's Avatar
Not a "problem" but I would pull the cover reseal it and add some fresh oil
bodyguy is offline
post #3 of 13 Old 01-20-2010, 07:07 PM
jeepgrl's Avatar
Maybe it's a silver thing! LOL My 07 does the same thing and it has about 15,000 on it. Hubby took it apart and sealed things back up and every once in a while she stills drips.
ND Jeep Girl~'07 Salvaged Silver Wrangler X 4X4 Hardtop~in the process of a slow renovation
Neoprene seat covers, Jeep cargo net, Rampage 2pc Safari top, Smittybilt XRC rear bumper w/ tire carrier
jeepgrl is offline
post #4 of 13 Old 01-20-2010, 07:12 PM
paramaniac's Avatar
i have to agree...
and ill add this (some will argue) get a set of lube lockers
oh yeah, use this as an opportunity to upgrade!!!
paramaniac is offline
post #5 of 13 Old 01-20-2010, 07:17 PM
mikeyfl's Avatar
mine does that but at the top of the cover.
havent noticed any drips.
mikeyfl is offline
post #6 of 13 Old 01-20-2010, 07:24 PM Thread Starter
jkmorrow's Avatar
Well I was looking for a reason to get new covers and maybe a regear does anyone see 5:13's in my future?
4" RC
35x17 BFG M/T KM's
Superchip Flashpaq
"Grey Ghost"
jkmorrow is offline
post #7 of 13 Old 01-20-2010, 07:43 PM
StubEXrube's Avatar
If you are planning to do a lift/ gear swap in the near future....you might just tighten the bolts (ALL of them- not just the bottom bolts) to approx 30 ft lbs. That way, you aren't draining/ replacing more fluid than you need to. If not, then as suggested-
remove the covers
drain
scrape all the existing RTV off the mounting surface
clean well
add a bead of fresh RTV
reinstall the covers
tighten to 30 ft lbs
add fluid to just below the fill hole
re-check the bolts after a week or so/ tighten if necessary.
StubEXrube is offline
post #8 of 13 Old 01-20-2010, 07:51 PM
WeGo4x4's Avatar
Just adding my 2cents...but it's always a good idea to check your breather tube to make sure it's connected. My front leaks from the breather quite often.
WeGo4x4 is offline
post #9 of 13 Old 01-20-2010, 07:52 PM
bodyguy's Avatar
Originally Posted by paramaniac View Post
i have to agree...
How could I forget lube lockers, they are worth the money and Phil at Trailduty can hook you up with a set
bodyguy is offline
post #10 of 13 Old 01-20-2010, 08:03 PM Thread Starter
jkmorrow's Avatar
Please be patient with me I'm some what new to this...but what are lube lockers?
4" RC
35x17 BFG M/T KM's
Superchip Flashpaq
"Grey Ghost"
jkmorrow is offline
post #11 of 13 Old 01-20-2010, 08:09 PM
Broncojohn's Avatar
A pre-formed over priced tube of RTV.
But some will argure differently.
Broncojohn is offline
post #12 of 13 Old 01-20-2010, 08:12 PM
bodyguy's Avatar
http://www.trailduty.com/product_inf...2163fdfcc63dec
bodyguy is offline
post #13 of 13 Old 01-20-2010, 09:00 PM
oO_Rogue_Oo's Avatar
LOL; yeah I just use my lowly $2 tube of RTV on mine and keep the other $20 for refreshments
2008 Rubicon 2 Dr 6 speed
Stone White
oO_Rogue_Oo is offline
