IPF's or Cibies? Which is the best? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 01-20-2010, 02:31 PM Thread Starter
I want to upgrade the sorry ass lights on my 2010 Wrangler but am torn between Cibies or IPF's. Anyone have any comparisons or suggestions?
copdude33 is offline
post #2 of 13 Old 01-20-2010, 03:31 PM
oO_Rogue_Oo's Avatar
I've got the Cibies and I can tell you they were worth every penny. Everyone who sees my JK with the headlights on asks me about them; they are that bright. Don't know anyone with the IPFs installed so can't help there but I can tell you the Deltas are not even close to the Cibies. Hope that helps some
2008 Rubicon 2 Dr 6 speed
Stone White
oO_Rogue_Oo is offline
post #3 of 13 Old 01-20-2010, 04:01 PM
what he said above
rob4607 is offline
post #4 of 13 Old 01-20-2010, 04:45 PM Thread Starter
Did you use normal wattage light bulbs or did you go with the high powered ones and upgrade the wiring?
post #5 of 13 Old 01-20-2010, 08:26 PM
I went with the 70/65W Osram bulbs and built my own wiring harness with a good quality 12 ga wire. They now have a plug and play wiring harness that saves you all that work that sells for $89 if I'm not mistaken
Stone White
post #6 of 13 Old 01-21-2010, 07:09 AM
Got a link to the Cibies website? Google turned up nothing.
2008 Patriot Limited 4x4
2010 Jeep JK Sport 2dr/6spd/3.73's
Go visit
...and tell your friends!
SmurfJK is offline
post #7 of 13 Old 01-21-2010, 07:27 AM
Hilldweller's Avatar
Here:
http://www.danielsternlighting.com/p.../products.html
and get the wiring harness here:
http://www.rallylights.com/
Or just get their plug-n-play kit that uses Hella reflectors. I hear that Cibie is better than the Hella but only marginally:
http://www.rallylights.com/detail.aspx?ID=4669
Safety fast,
Get to know
Hilldweller is offline
post #8 of 13 Old 01-21-2010, 07:51 AM
I have the cibies and am very pleased.....upgraded harness & osrams.......very bright....especially on high beams....
can only compare to stock...which was crap.
BIGCAT is offline
post #9 of 13 Old 01-21-2010, 08:21 AM
How long are your bulbs lasting?
EmbarkChief is offline
post #10 of 13 Old 01-21-2010, 08:27 AM
non issue for me so far.....but there are several other threads about it. Based on what I read....I need to get some back up bulbs. Length of life is all over the map. I am certain that weather conditions are playing a big factor in this calculation. Hot/Cold/Moisture/Freezing....etc..
BIGCAT is offline
post #11 of 13 Old 01-21-2010, 12:01 PM
Had mine pretty close to a year now and the bulbs are fine
Stone White
post #12 of 13 Old 01-21-2010, 03:14 PM
Thank you for the replies. Bulb life playes a significant part in my decision.
post #13 of 13 Old 01-21-2010, 04:58 PM
dsy
dsy's Avatar
I got over a year with my last set of Osram 85/80. I just changed them out knowing they were problably going soon. I order a new pair to keep in the glove box every time I replace a set.
07 Flame Red Unlimited Rubicon, 5.7 hemi, RCV shafts, 35" KM2's, AEV 3 1/2 lift, , AEV rear swing away Carrier, AEV Snorkel, LoD front bumper with Warn powerplant, 45qt Engel refrigerator / freezer. , Marchal E-Code lamps
DIY Hemi build
dsy is offline
