sucked some water up my intake - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 09-22-2014, 05:48 AM Thread Starter
so i sucked a little bit of water in my intake and hydrolocked my motor.its a 2008 jeep wrangler with 100k miles. i was wondering what the best way to go about fixing this is. im new to the fourm and any help would be greatly appreciated!!
thejeepguy08 is offline
post #2 of 12 Old 09-22-2014, 06:12 AM
Buy another motor. All the things spinning and then they suddenly stop causes bad things to happen on the inside of a motor.
post #3 of 12 Old 09-24-2014, 12:08 PM
Call one of the Hemi/LS motor conversion companies - they have plenty of take out motors you could likely buy for less than your local pick and pull. And way less than fixing your current motor if any serious damage happened.
BigJk is offline
post #4 of 12 Old 09-24-2014, 01:31 PM
LoneJK's Avatar
having hydrolocked a 650 twin cylinder engine on an ATV i can attest to this. bent parts, broken rings, ect
"Gremlin"
LoneJK is offline
post #5 of 12 Old 09-24-2014, 02:40 PM
White13JKUR's Avatar
This one time, I totally tried to compress water with a 4.0L Ford.
...and guess what? Water does not compress very well. I saved one of the pistons/rods to remind myself in case I forget.
note the twisted connecting rod and the nice tone of lizard-belly-blue around the wrist pin.
And, no... sadly, I could not swing a warranty claim and had to buy a then new and rare 1991 4.0L ford V6 through the Mazda supply chain.
White13JKUR is offline
post #6 of 12 Old 09-24-2014, 02:55 PM
How much is a "little bit" water?
stretch79 is offline
post #7 of 12 Old 09-24-2014, 03:12 PM
I've never noticed a color change on bent conrods before...is that normal? Is there a rapid temperature change or something going on there?
'12 Sport...I need to up my powerball investments, mods are expensive!
Godholio is offline
post #8 of 12 Old 09-24-2014, 03:20 PM
not sure. only the most badly bent rods showed this. I just nabbed this one (back in 1991) it was the worst.
FWIW, the motor was hot - we had just arrived after a 3 hour drive up to the mountains.
post #9 of 12 Old 09-25-2014, 09:48 AM
jacktuttle's Avatar
Post Rod Color
The color on the rods is from installing the wrist pin. You heat the small end of the rod in a rod heater, when it's hot enough you quickly put it in place on the piston and push the pin in. A few seconds and the rod cools, the end shrinks back to normal size and the pin is installed. I've put hundreds of wrist pins in that way. The other method of installing wrist pins is to put them in a press. I've done a lot that way too, but if anything goes wrong you destroy the piston.
jacktuttle is offline
post #10 of 12 Old 09-25-2014, 09:55 AM
jacktuttle's Avatar
Post Insurance Claim
If you have full coverage insurance you should try filing a claim with them. Depending on where it happened (If you can claim a road hazard) and your coverage, it may be covered.
There are a couple of back roads in Big Bear area that cross water. I had a friend that hydro locked his motor trying to cross the water (at high speed)and destroyed his motor. His insurance too care of it. He was in a Subaru. It had the intake at the front of the car right below the hood and took in the water nicely! He claimed road hazard.
post #11 of 12 Old 09-25-2014, 10:57 AM
Makes sense, thanks!
Godholio is offline
post #12 of 12 Old 09-25-2014, 11:42 AM
Good luck with that. Been there. Done that too. Farmers kicked it to the curb.
