3.6 manual 3.21 gears - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-14-2014, 10:35 AM Thread Starter
Looking for someone with a 3.6, manual tranny, 3.21 gears and stock 225 75 16 tires. If you could give me the reading on your tach when you are in 6th gear and doing 70 mpg I would be grateful. Just put 305 70 16 tires on with 3.73 gears recalibrated the speedo and I was wondering how close to stock my gearing is. Thanks for the help.
Strider is offline
post #2 of 8 Old 09-16-2014, 03:22 PM
sixstring's Avatar
Download a GPS speedometer app on your phone (there are a ton of them) and compare the reading to your speedo. A 305/70/16 is about 33 inches tall, so 70mph should be around 2100 rpms.
sixstring is offline
post #3 of 8 Old 09-17-2014, 02:31 AM
you regeared to 3.73?
CraigP is offline
post #4 of 8 Old 09-17-2014, 07:25 AM
ndtguy's Avatar
I will check today on the way to work. I want to say it is just a touch over 2k rpms.
NDTguy
2017 JKU Sport S
ndtguy is offline
post #5 of 8 Old 09-17-2014, 09:25 AM
ndtguy's Avatar
Verified 2100 on the tach. I have no idea the percentage of error, but there you go. Hope it helps.
NDTguy
2017 JKU Sport S
ndtguy is offline
post #6 of 8 Old 09-22-2014, 07:01 AM
Also note that chart provides engine speeds based on when the tranny is in the 1:1 gear. So,for the manual, that will be 5th gear. For the autos, fourth gear I believe.
SJDano is offline
post #7 of 8 Old 09-22-2014, 08:07 AM
sixstring's Avatar
The chart is based on final drive ratio. 6th gear for manual, 5th for auto.
post #8 of 8 Old 09-22-2014, 06:46 PM Thread Starter
Thanks for all the info. I ordered it with 3.73 gears because I knew I was going 305/70/16s. I was interested on how close to stock I got. With the OEM 225/75/16s it was geared way to high with the 3.73s but with the 305/70/16 it seems to be geared just right. Thanks again for the info.
Strider is offline
