Buying a 4 Door What One!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 01-14-2010, 04:01 PM Thread Starter
Sherlock's Avatar
Ok so i have had a wrangler x 2 door for a couple of years and i want to step up to a 4 door. My intent is to put 37s on it and use it as a daily driver for the next year then become a recreational vehicle.
I am currently looking at 2 different ones. The first one is a 2008 Sahara 4 Door 2wd, auto, with 5,600 miles on it and it is $18,700. The second one is a 2008 Rubicon 4 door, manual, hardtop and soft top, 18,000 miles on it and it is $25,600.
I can do most of the drivetrain work myself with the 2wd and anything i can't do i will lure my friends with to help me.
I would really appreciate some help in this situation any opinions are welcome.
Aaron
"When life gives ya lemons, ya shut up and eat your lemons" Clint Eastwood
Sherlock is offline
post #2 of 20 Old 01-14-2010, 04:10 PM
ALASHA's Avatar
Man where to begin...
First since you live in Canada so I am making the assumption that it does snow and that 4wd would be preferable. You can always convert the 2wd to 4 but that is alot of hassle and more money down the road so I would at least limit my search to 4wd unlimiteds.
You want to run 37s on it. If you plan on strengthening which ever axles you do get (which at the very least should C gusset with 37s) then I think the 44s from a Rubi would be a better starting point. If you plan on upgrading completely to a prorock 44 or dana 60 for example, then it obviously doesnt matter which axle you get originally.
The last part is your definition of recreational and how far do you want to take it. If you have a complete lift in mind the money all saved up then the better suspension that comes on a rubi isnt something you really need but if you plan on upgrading gradually then the Rubi suspension is good to have until you have the money to make changes.
Just some thoughts and I am sure more people will chime in on this...
ALASHA is offline
post #3 of 20 Old 01-14-2010, 04:24 PM
StubEXrube's Avatar
As stated, it really comes down to your intentions (modifying & driving/ wheeling). The $6,900 difference between the two = a good deal of mods. The difference of 12,400 miles is not as significant imo, especially considering that you have no idea how well one was cared for over the other.
If it was me personally, and I had the extra $$$, then I would probably opt for the Rubi, as long as the 6 speed doesn't bother you (or your spouse?). I really just don't care for 2wd Jeeps, nor would I like the thoughts of taking the time and extra money to convert it to 4wd. JMO
StubEXrube is offline
post #4 of 20 Old 01-14-2010, 07:19 PM Thread Starter
Sherlock's Avatar
Thanks guys all good points, i was doing some research and i am heavily leaning towards the rubi and i will be moving to the west coast here shortly where i have no garage to work on a 2wd to convert to 4wd. I just need to get a hold of the bank and sell my soul
Sherlock is offline
post #5 of 20 Old 01-14-2010, 07:21 PM
Split the difference and get a 3 wheel drive.
karnuvore is offline
post #6 of 20 Old 01-14-2010, 07:43 PM
I didn't think that the Sahara came in a 2wd version?. But here is my .02 worth... for the 7k difference get the Rubi. You will allready have lockers and bigger axels and 4:10 gears so when you turn it into a trail rig you'll already be well down the build road.
post #7 of 20 Old 01-14-2010, 07:47 PM
sniper41's Avatar
I'd go rubi too!
Jersey
Crew
sniper41 is offline
post #8 of 20 Old 01-14-2010, 09:09 PM
jaker's Avatar
if you are not going to do alot of hard off roading , go with the 2wd and put in a elocker in the rear
jaker is offline
post #9 of 20 Old 01-14-2010, 09:11 PM
RotorHead's Avatar
Just make sure you get a red one. They are faster than the other ones.
RotorHead is offline
post #10 of 20 Old 01-14-2010, 09:13 PM
X2 on that. Yes, they are much faster
post #11 of 20 Old 01-14-2010, 09:21 PM
bodyguy's Avatar
Definitely go with the rubi, I'm sure if you add up the t-case, front axle, drive shaft, shifter, t-case adapter, rear drive shaft, rear locker, and then add your lift, tires and wheels to it. Just get the rubi buy some front axle gussets and enjoy, upgrade as you go (or break shit) I think you will be happier.
bodyguy is offline
post #12 of 20 Old 01-14-2010, 09:59 PM
Yeah, good point. I forgot about the lower geared T-case that comes in the Rubi.
post #13 of 20 Old 01-14-2010, 10:03 PM
07unlimitedx's Avatar
Where did you find the 2wd? When I got mine 2wd wasn't even an option.
07unlimitedx is offline
post #14 of 20 Old 01-15-2010, 04:15 AM
They have offerd them all along, only on the Unlimited though.
2007 Redrock X two door
Auto
Hardtop
D44 rear
17" Moab wheels
32" BFG M/Ts
Rubicon Rock Rails
Airaid intake
Infinity speakers
pearl-drum-man is offline
post #15 of 20 Old 01-15-2010, 08:20 AM Thread Starter
Sherlock's Avatar
It is located in nove scotia, the guy brought it up from the united states. I was kinda shocked that there was one in canada too.
Sherlock is offline
post #16 of 20 Old 01-15-2010, 08:44 AM
waterboy202's Avatar
Red paint is good for 30 more horsepower!
waterboy202 is offline
post #17 of 20 Old 01-15-2010, 08:56 AM
ALASHA's Avatar
Its also good for higher insurance premiums
ALASHA is offline
post #18 of 20 Old 01-15-2010, 09:09 AM
dickyB's Avatar
Send a message via AIM to dickyB Send a message via Skype™ to dickyB
which one? buy mine 07 rubi unlimited with 44k miles and already on 35's. $21k saves you a lot of money, but you have to come to maryland to get it.
Originally Posted by Chris Hansen View Post
I like driving my jeep around while wearing a suit....it says I'm formal, but I'm here to party.
dickyB is offline
post #19 of 20 Old 01-16-2010, 01:22 AM
Are jeeps cheaper in canada? wouldn't they be more expensive cuz the terrain sucks up there?
odogg is offline
post #20 of 20 Old 01-16-2010, 06:05 AM Thread Starter
Sherlock's Avatar
Well the Canadian dollar is increasing in value compared to the US dollar and most jeeps are made in the US and shipped up here so they are cheaper for the time being. Yes our terrain is different and for 5 months of the year covered in snow but it is still fuck as f%#$k to wheel on.
Sherlock is offline
