Warrior Tube Door Mirror Kit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 01-12-2010, 04:09 PM Thread Starter
FUN LS1's Avatar
Looking at this:
http://www.rdmoffroad.com/warrior-pr...irror-kit.aspx
Anyone have any experience with this kit? Mirrors in decent spots? It says bolt on but I'm guessing I'd have to drill on the mirror brackets.
-Established April 1, 1983-
No dues, No rules, No President
ALL FUN!
FUN LS1 is offline
post #2 of 5 Old 01-12-2010, 05:36 PM
USAntigoon's Avatar
I have Warrior doors and was considering buying this kit.. But this solution I came up with is very very cheap..6 inch BikeMaster mirrors..($9.00 a piece at Amazon)
I leave these mirror in place hence a one time adjustment will do.. No messing around with the OEM door mirrors and I kind of like the looks instead of these bulky mirrors..
USAntigoon
USAntigoon is offline
post #3 of 5 Old 01-13-2010, 04:41 AM
drmeece's Avatar
I have those and they vibrate so bad you cant see. I stoped using them.
drmeece is offline
post #4 of 5 Old 01-13-2010, 07:22 AM
USAntigoon's Avatar
Mine don't vibrate and I am very happy with them. Be sure you have the one with the solid connections..You have these type of BikeMasters..?
USAntigoon
post #5 of 5 Old 01-13-2010, 10:52 AM
Jason @ Warrior's Avatar
The bracket requires 3 holes to be drilled through the triangle gusset at the top of the door. Bolts are supplied to bolt the mount to the door.
Those particular mirrors are very solid and work quite well. They work even better if you put a rubber snubber of some sort on the door jamb to hold the tube door more steady.
Jason @ Warrior is offline
