Top cracked - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 09-04-2014, 07:35 AM Thread Starter
SoK66's Avatar
Top cracked
Just discovered this crack in my '09 JKUR's hard top. Anyone else had this happen? Any ideas on what this will take to fix? Seems like a weak spot.
SoK66 is offline
post #2 of 9 Old 09-04-2014, 07:36 AM Thread Starter
SoK66's Avatar
This may be the excuse I was looking for to put the factory soft top on that's been in the boxes since '09....or maybe not. ;-)
SoK66 is offline
post #3 of 9 Old 09-04-2014, 09:06 AM
That sucks man! I have not seen that. I'm sure it can be fixed. Does the crack go through to the other side?
da20captain is offline
post #4 of 9 Old 09-04-2014, 09:43 AM
tiltz's Avatar
I've seen that on a couple jeeps that wheel. One guy was cracked on both sides of the window
tiltz is offline
post #5 of 9 Old 09-04-2014, 10:05 AM
Jeepineer
JKred07's Avatar
Mine is cracked in the exact same spot. I smacked it on a tree at the driver side right above the window and it cracked there.... didn't break the window or the hardtop where I hit it though.
I have a friend who's fairly experianced with fiberglass repairs on boats and has told me to just bevel the crack and fill it with resin. If there is a significant gap, then add shredded fiber to the resin. Sand, then paint.
Unfortunatly since I have a soft top as well it's just another thing I haven't got around to.
-Mike
JKred07 is offline
post #6 of 9 Old 09-05-2014, 06:10 PM
the hardtop is NOT fiberglass..... do not try to fix it with fiberglass resin, it will not hold. go to a auto body paint store, they have the correct epoxy to mend the hardtop and paint.
jklarry09 is offline
post #7 of 9 Old 09-05-2014, 09:24 PM Thread Starter
SoK66's Avatar
Thanks!
SoK66 is offline
post #8 of 9 Old 09-05-2014, 09:39 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I took a 2.5" chunk out of the corner of my hardtop when one of my ratchet straps used for hoisting let go and let the top drop onto the corner of the tub. I replaced the material lost with a plastic plumbing epoxy and repainted it with Rustoleum bedliner coating. You'd have to really be looking to notice it. That might be an option for repair.
JKCTAZ is offline
post #9 of 9 Old 09-06-2014, 03:27 PM Thread Starter
SoK66's Avatar
Well, it appears one is supposed to use SMC epoxy to repair these SOBs, and the best recommended was something called 3M 5883. Ordered a kit and we'll see how it goes. I drilled both ends of the cracks (there are two) and hope they hold until the expensive goo shows up.
SoK66 is offline
