100,000 Mile Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 08-28-2014, 06:47 PM Thread Starter
Here is my question, I am coming up on 100,000 miles on the Jeep. Mostly stock, 2007 Unlimited. I'd rather not have any surprises.
I am really looking to make a checklist of things to look for and replace/repair before it becomes a problem.
So what known issues should I be looking for?
__________________________________________________ ____________________________________________
Give me a diablo sandwich, a Dr. Pepper, and make it quick, I'm in a god-damn hurry.
Titus is offline
post #2 of 8 Old 08-28-2014, 11:59 PM
gerryjk's Avatar
Some you can check/replace are plugs, air filter, power steering fluid, brake fluid, coolant hoses and belt, then maybe flush the radiator. Also change the trans and front/rear axle fluids.
gerryjk is offline
post #3 of 8 Old 08-29-2014, 07:37 AM
wildchild's Avatar
pretty much covers all of it.
wildchild is offline
post #4 of 8 Old 08-29-2014, 08:02 AM
Take a close look at brake rotors.
COFBack is offline
post #5 of 8 Old 08-29-2014, 01:50 PM
wildchild's Avatar
LOL my rear rotors were gone before 100K both calipers went out in the rear. fronts are still good at 134K didn't change front pads until 115K or so.
post #6 of 8 Old 08-29-2014, 02:31 PM
ronjenx's Avatar
I found the checklist in the owner's manual very helpful.
For the 2007, it lists things to look at up to 150,000 miles.
ronjenx is offline
post #7 of 8 Old 08-29-2014, 03:56 PM
You may want to consider replacing the water pump and thermostat while the coolant is out. They are not expensive and not too difficult to swap out. An $8 thermostat can leave you stranded on the side of the road.
nj jk is offline
post #8 of 8 Old 08-29-2014, 10:27 PM
Random Dude
^^^ What all they said, and maybe throw in a new fuel filter + check all suspension link joints/bushings, wheel bearings, u-joints, and critical fasteners.
Give it a good reach-around once in a while, and it will be less resentful when you give it a pounding (that sounds dirty, for some reason )
EDIT: Oh, and check or replace your PCV valve if you never have, before your engine starts sucking down oil like dollar beers.
ExWrench is offline
