Bar Lights & LED Lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-16-2014, 05:38 PM Thread Starter
Are there any ideas for securing these better to mitigate theft? Are there others that have concerns when you park your Jeep that someone is going to take tis very expensive merchandise? Just looking for thoughts
kdon2420 is offline
post #2 of 6 Old 08-16-2014, 08:30 PM
UnlimiDozer's Avatar
http://www.carolinametalmasters.com/...for-led-lights
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #3 of 6 Old 08-19-2014, 11:30 AM
leman's Avatar
That 2nd one looks pretty good, but the problem I see with almost every other security nut out there is that they can still be removed with vice grips.
2008 steel blue sahara
with some doo-dads
leman is offline
post #4 of 6 Old 08-19-2014, 12:10 PM
The second one is specific to that particular mounting style for the light bar, but it could be adapted to the PSC style mounting with a cup shaped washer so it would sit down inside. Wouldn't be theft proof, but it would help. You could also weld a section of tube onto the PSC mounts that the security device would sit down inside, so there would be no way to remove it without the key.
. . . and here are some more ideas:
https://www.jkowners.com/forum/showthread.php?t=196337
My Build Thread:
I'm the NRA
JOIN HERE:
post #5 of 6 Old 08-20-2014, 01:03 AM
For normally mounted lights (like single bolt units) I use locking nuts on the mounting bolt, then I replace the commonly used Allen keyed socket head bolts on the lights themselves with the Tamper Proof Torx headed bolts.
Not too many people running around with Tamper Proof Torx keys in their pocket....
LeighP is offline
post #6 of 6 Old 08-21-2014, 07:55 AM
Oconeeoffroad's Avatar
KC HiLites & ICI Innovative Creations has LED Light Bar Locks to help protect your investments....
KC Hilites has introduced some Light Locks too now!
1/2" Bolt Lite Locks - KC Hilites
CNC'd Light Locks are designed to provide extra security for your lights. Manufactured from hardened steel and coated with corrosion-resistant zinc finish and matching key, these light locks perform and protect at the same time. Each kit includes two locks and one key.
100% CNC Machined Hardened Steel Construction
Zinc Coated For Protection From Corrosion
1/2-13 Thread Pitch
Designed in the USA
Free Shipping on web site orders over $50
Use Promo code JEEP10 for 10% off web site orders
Open 9-6 M-F 10-1 Saturday 706-534-9955
Oconeeoffroad is offline
