Not On-Board Air, But... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 08-10-2014, 08:08 PM Thread Starter
BigTB's Avatar
I just got done setting up my compressor. It will be nice to be able to air down (and back up again) on the next trail ride.
I was originally planning on installing the compressor (went with an ARB) in the Jeep and setting up on-board air. But I couldn't help coming back to the fact that the compressor would be as useful in my work truck as in my Jeep, so I decided a portable setup would be better.
I bought a 28" tool box and just mounted everything in that. I bought a 2 gallon steel tank to go in the box along with the compressor. I modified the wire harness that comes with the ARB compressor to work with the setup. I soldered two alligator clamps to the wires for the battery connection. I used the pressure switch included with the compressor and the switch I had originally purchased to go with my SPod. I didn't know the compressor came with a switch, so I ended up with two, oh well.
Just thought I'd share. I haven't used it yet, but will report back once I do if anybody is interested.
BigTB is offline
post #2 of 14 Old 08-10-2014, 08:09 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Nice!
JKCTAZ is offline
post #3 of 14 Old 08-10-2014, 08:14 PM Thread Starter
BigTB's Avatar
Also, there's enough room in the box for a few extra tools, an air-down tool, gauge, spare valve cores, plug kit, etc. Should be a handy thing to have on the trail (or in the work truck). The only extra tool in there so far is the air blower visible in the picture.
I plan on adding a gauge to the tank eventually. I have an extra port on the plumbing, but it's just plugged for now since I don't have a gauge yet.
BigTB is offline
post #4 of 14 Old 08-10-2014, 08:16 PM
NascarRubicon's Avatar
Me likely. Great thinking.
"Eat Liquid Gold"
NascarRubicon is offline
post #5 of 14 Old 08-11-2014, 02:27 AM
petef550's Avatar
That's cool, you might want it throw in a pair of work gloves god knows the end of the air line gets hot as hell when the compressor has been running for a while.
its all about the crawl ratio.
petef550 is offline
post #6 of 14 Old 08-11-2014, 04:26 AM
bgall's Avatar
Nice flexible setup. I like it.
I have jeeps. I do shit to them.
bgall is offline
post #7 of 14 Old 08-11-2014, 08:25 AM
That set up is what a lot of guys in Australia run....you never really see people with charged air tanks...too much of a hassle getting them filled.
Nice job!
LeighP is offline
post #8 of 14 Old 08-11-2014, 09:22 AM Thread Starter
BigTB's Avatar
Thanks guys. It will be nice to finally have a compressor. I've plugged and filled a flat with a hand pump before. Not fun.
Gloves are a good idea to add to the box, thanks for the suggestion.
BigTB is offline
post #9 of 14 Old 08-11-2014, 09:49 AM
Random Dude
I dig it!
Only unmentioned thing I can think of: the compressor will get hot - keep an eye out in case the heat is enough to soften or deform the plastic box.
The compressor appears to be mounted in the box, correct? You may need to put some stick-on heat shield matting inside the box near the compressor.
ExWrench is offline
post #10 of 14 Old 08-11-2014, 10:32 AM
LoneJK's Avatar
I have and used the toolbox in question for about 5 weeks now, its a thicker 1/8 inch thick wall toolbox with an OK water seal from Bostitch. It(or maybe just mine) does like to warp a little bit inward around the latches before buckling them but heat has never been much of an issue(hot welding pliers, chipping hammer ect). I definitely will be following this one.
"Gremlin"
LoneJK is offline
post #11 of 14 Old 08-11-2014, 11:12 AM Thread Starter
BigTB's Avatar
I dig it!
Yeah, the compressor is mounted to the box. We'll see how it goes.
I did bolt the compressor to the side of the box, rather than the bottom, so it would be closer to the top and would possibly cool a bit better. Also, the handle area of the side of the box where the compressor is mounted is a bit thicker than the rest of the box.
Hopefully it will hold up ok. I'd be a little surprised if the mounting bracket of the compressor got hot enough to melt the plastic (a bit of deformation wouldn't be too big an issue as long as it wasn't enough to cause it to fail), but time will tell. If it seems like it's an issue once I start using it I could mount the compressor on stand-offs instead of against the plastic and put a layer of foil on the box to reflect the heat.
Once I've used it I'll report back with how it goes. It may be a couple weeks before I get out on the trails again. I will likely use it sooner than that, but maybe not for as long as it would take to air up four tires (or eight if my buddy begs enough).
BigTB is offline
post #12 of 14 Old 08-11-2014, 11:44 PM
BumpInTheRoad's Avatar
Also a good place to keep a tire plug kit, some spare valve stems, cores, caps, valve core tool, etc.
I'm a JKO Reject
BumpInTheRoad is offline
post #13 of 14 Old 08-13-2014, 01:49 PM
bass5money's Avatar
nice job..now market that crap and sell it...lol
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #14 of 14 Old 08-13-2014, 02:27 PM
illyb's Avatar
Very nice. If you start to notice the heat is too much for your toolbox, heat sinks or some finned tube (used as mounting spacers) may help out. Or you could cut holes in the side of the toolbox to mount a couple of computer fans to keep air circulating through the box while the air compressor is on.
illyb is offline
