Another locker in front question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 08-05-2014, 03:47 PM Thread Starter
Just got my 15 2 dr. Ordered wheels and tires and set up appointment to have a True Trac installed in the rear. Asked the shop for an estimate on an Aussie for the front and I was told that they won't put a locker in the front of a JK. He said the wheel base is to short. My question is: who has a locker in front of their 2dr JK and have you had any problems. Did a search on lockers up front and got a ton of info most of it good, but nobody stated if they had a 2dr or 4dr. I can't see it making that much of a difference.
Strider is offline
post #2 of 18 Old 08-05-2014, 04:14 PM
Are you driving in bad weather often where you need 4x4? If so, a selectable is a much better option for you.
...If not, then tell them to put the locker in, you'll pay the bill and they can leave you alone.
post #3 of 18 Old 08-05-2014, 04:22 PM
sstoner's Avatar
I would never talk to that shop again. RUN AWAY!
I have the Eaton in the rear and Detroit in the front. I don't even know its there in 2wd. In 4WD its pretty well behaved..maybe tight to turn when up on rocks etc but that's normal.
2013 2 Door
sstoner is offline
post #4 of 18 Old 08-05-2014, 04:22 PM
SoK66's Avatar
The factory installs lockers front & rear in the Rubicon. I think the issue with the shop is that you want to put an automatic locker in front, wich on a street rig might be a handfull, particularly on ice. If it were my rig I'd do the rverse of what you're considering, Tru-Trac in front and a manual locker, like ARB or E-Locker in the rear.
SoK66 is offline
post #5 of 18 Old 08-05-2014, 04:58 PM
Catfish's Avatar
truetrac or full?
FWIW I have a grizzly in back and a eaton E awaiting install for the front of my 4dr.
Catfish is offline
post #6 of 18 Old 08-05-2014, 05:01 PM
You really want select-able's on a short WB , on slippery roads (don't know if you use as DD) you can be caught , not payin' attention . JMHO . It happens quick . Pretty side up if ya catch my drift , just safer .....regards k.
slick pickel is offline
post #7 of 18 Old 08-06-2014, 06:37 AM
2Door's Avatar
Who said run away from that shop? Follow that advice, cause the 2 Dr JK is the longest swb Jeep made, so ask the shop how many TJ's or CJ's they've refused.
Anyway, I love the selectable locker in the front of mine. I used it this weekend for the tight trails. Click it on for the rough spots, click it off for the twists and turns. I also liked it because given the awesome power steering system that Jeep blessed the JK with, I could flip off the locker and not make the steering do quite so much work. I've found that on longer trail rides (we were out about 8 hours) unless you only use the locker when necessary, it does make the pump whine sometimes. I'm trying to avoid too much abuse on the PS system so the selectable helps that.
But a good buddy of mine has two Detroits in his CJ7. Other than the odd 3 point turn, he does just fine as the locker tends to unlock to get around corners in the trails (as it should). I'd still opt for a selectable in your situation though
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #8 of 18 Old 08-06-2014, 06:57 AM
While selectable lockers are nice, the Aussie locker is good for its price point.
I had one in my 2007 2-door X. Never had an issue in bad weather, never got "caught out". It handled great in or out of 4x4, and on all kinds of terrain and conditions. It also drastically improved the capability of the Jeep offroad. Sandy hillclimbs that had me stuck previously were easy once I'd locked it.
I say tell the shop they're full of it.
As proof I offer this. Bill, President of Aussie Locker, and a local mechanic, Ryan, installing my locker in my old JK:
Grimscale is offline
post #9 of 18 Old 08-06-2014, 08:03 AM
sstoner's Avatar
I said it! RUN. To tell someone not to do locker because the wheel base is to short. ..Iam sorryb that's lazy advice.
Does that mean you cant use a selectable? Come on now. ..
Ihave the Detroit Auto locker in the front and its awesome.
sstoner is offline
post #10 of 18 Old 08-06-2014, 08:05 AM
sstoner's Avatar
Originally Posted by Catfish View Post
truetrac or full?
Greg, its full - auto locker....
sstoner is offline
post #11 of 18 Old 08-06-2014, 08:16 AM Thread Starter
Thanks for the info. This is my DD and I'm putting a TT in the rear so I need to go cheap with the front. I live in SE Mich. and the only time I'm going to need a locker up front is when I go up North hunting in November or hit the fire trails. A selectable is out of the question, to much for the little I'm going to use it. I've read lots of threads from those that have lockers in the front and they say they're not an issue, but I was just wondering if the longer wheel base made that much of a difference or the shop I'm at was just covering their a--. The shop has been there forever and I trust them. All they do is Diffs and axles. I had them put TT's in the front and rear of my 85 Chevy PU when it was new, and never had any issues.
Strider is offline
post #12 of 18 Old 08-06-2014, 11:22 AM
Catfish's Avatar
"Greg, its full - auto locker.... "
sweet, I've driven some of our friends around here bat shit crazy asking locker questions and then blazing my own cheap auto trail irregardless of all the good advice you can get on the net.....
Nice to see a pic of someone manufacturing something in the US too!!!!!
Catfish is offline
post #13 of 18 Old 08-06-2014, 04:59 PM
The street won't pose a problem with an Aussie in front since the axle isn't getting power. No power, no lockup.
The rear though is going to lock every single time you hit the gas which will mean a lot of tire squeal and wear.
In 4-hi or 4-lo the front being an auto locker is going to destroy your turning radius. Locked front axle will not want the jeep to turn at all.
Personally I had them in my xj and I didn't like them at all on the street and I didn't feel safe letting anyone drive my jeep on the road. They do exactly as promised off-road. Cheap lockers get you further but also kind of suck because most of the time you'd like them off.
Hitchhiker is offline
post #14 of 18 Old 08-07-2014, 03:21 PM
I have a 2dr 09 with an aussie in the front and the factory LSD in the rear and I love the combination. it does not restrict me on turning in 4WD. the ONLY restriction I have incountered is in 2WD in tight turns which must be done slowly. I run in alot of water and deep sand, so I am in 4WD most of the time in those conditions. most of the people I wheel with do not know I have a front locker and think I am a really go driver to go where I go. yesterday I was called upon to pull out a Rubican, twice. on the street you will not know it's there,,,until you make a really tight turn, then it's gets noisy but still works. no problem on slick roads either.
jklarry09 is offline
post #15 of 18 Old 08-08-2014, 10:18 AM Thread Starter
Anybody living in the snow belt with a locker up front. I'd love to here from you, and how it handles in snow in both 2 WD and 4 WD. Talked to the shop putting the rear TT in and got a price for a TT in the front, no freaking way. So it's a lunchbox in the front or nothing I guess.
Strider is offline
post #16 of 18 Old 08-08-2014, 07:51 PM
Would you consider Western NY a part of the snowbelt? I drove that '07 with the Aussie for two years, day in and day out, through all sorts of stuff including snowstorms that were almost blizzards. That locker never once caused me a problem.
I say go for it.
post #17 of 18 Old 08-09-2014, 02:26 AM
petef550's Avatar
I got an Aussie up front and a Detroit out back. And they work perfect. good luck !!!
its all about the crawl ratio.
petef550 is offline
post #18 of 18 Old 08-09-2014, 06:09 AM Thread Starter
You know what, no balls no glory. I'm ordering it Mon. screw it. Thanks for all the input. I've got my 305 70 16s going on today.
Strider is offline
