Premier Soft Top???? Anyone?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 08-02-2014, 09:15 PM Thread Starter
Redjk07's Avatar
Unhappy Premier Soft Top???? Anyone??
Does anyone else have a factory Premier a Soft top? My 13 JK Unlimited came with both tops and the soft top is like an actual soft top and the arms are spring loaded, and I don't know how to remove it to get more room in the back with the hard top on?
Redjk07 is offline
post #2 of 9 Old 08-02-2014, 10:37 PM
Unbolt the hardtop and remove it.
Unbolt the brackets that attach the soft top arms to the roll bars on each side and remove the soft top. Replace the hardtop....don't over tighten the bolts or the screw retainers for the freedom panels.
The factory ships the soft top fitted under the hardtop, but the original owner is supposed to remove one or the other roofs...they aren't supposed to both be fitted at the same time.
LeighP is offline
post #3 of 9 Old 08-03-2014, 07:36 AM Thread Starter
Redjk07's Avatar
I understand how to remove the hard top and the bolts for the soft top but when I take the bolts out for the soft top it has a piece where the arms are attached that is spring loaded, I don't want to screw something up because there is a lot of tension on the bracket, when I unbolt the brackets. The other jeeps have never came with this kind of top. It is more like a convertible top material is a soft cloth type not a more durable material.
Redjk07 is offline
post #4 of 9 Old 08-03-2014, 07:37 AM
Guruman's Avatar
There is more to it in the premium spring-assist tops. There is a small strap you are supposed to use to "lock" the spring assist mechanism when you remove the top. Otherwise the spring tension keeps pressing the top hardware into the mounting brackets.
Sorry I do not have much better description. I only know this from installing mine recently. It came in the box with the locking straps installed with a big notice that said not to remove them until the top was mounted.
_
Guruman is offline
post #5 of 9 Old 08-03-2014, 06:17 PM Thread Starter
Redjk07's Avatar
This is what I am running into when taking the bolts out the spring assist is putting a lot of pressure on the brackets and I don't want to just remove it and break something. I bought the jeep used but I think I have all the straps I will have to do some more digging!
Do you know if the strap with the snap on it that is already attached to the top have something to do with that.
I put the Owners manual CD in this morning and didn't get to much out of it either. I have even YOUTUBED it and have came up with nothing!!
Redjk07 is offline
post #6 of 9 Old 08-03-2014, 07:48 PM
It is the strap with the snap clip. The loop on the bottom end slides over part of the bracket near the hinge.
ivantate is offline
post #7 of 9 Old 08-04-2014, 07:03 AM Thread Starter
Redjk07's Avatar
You wouldn't have any pictures of how to use it and how to clip it??? Any info would be great!
Redjk07 is offline
post #8 of 9 Old 08-05-2014, 10:35 AM
sixty5vdub's Avatar
I have removed and installed the '13 Premium Soft Top that I bought for my '07 twice. At no time have I used any straps (used top didn't come with any straps).
I just lay the soft top on the Jeep, in the fully extended (closed) position, and attach the brackets to the sport cage. I don't tighten any of the hardware down until all 4 bolts are threaded about half way, to keep things from binding up. Takes all of 5 minutes, using a socket attachment on my cordless drill.
I think you could install the top in the folded (open) position as well, just might have to have a second pair of hands to hold things in place. But I haven't tried this method, as the first one I mentioned works just fine.
AMP
AMP
sixty5vdub is offline
post #9 of 9 Old 08-05-2014, 10:46 AM Thread Starter
Redjk07's Avatar
AMP
That is what I was thinking about doing as well. Is try taking it off in the UP position. The reason I am asking all these question is because we are planning on going to the 4 wheel drive jamboree in Indy in the middle of Sept and my son likes the way the Jeep looks with the top completely off and so do I. I just want to make sure I can get it off and back on without to much help when we are over there. I am going to try taking it off before we go. And I want it off and out of the way this winter when I get ready to put the hard top back on. Thanks
Redjk07 is offline
