SLOPPY STEERING and WOBBLE - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 08-01-2014, 12:48 PM Thread Starter
acopper123's Avatar
Hey Guys! So I added takeoff springs (18/59) and Rubio shocks today. Awesome lift results of almost 2" from my 14/55's and it looks like a totally different stance, but I immediately noticed that my steering was sloppy and making L/R turns requires almost a complete revolution of the steering wheel! This was NOT the case prior to the install!
Can someone tell me WHY this is, and what I can do to correct it? I was under the impression that nothing about the drive/handling would change.
Thanks!
acopper123
2010 Wrangler JK Sport
Black Forest Green Pearl
Mopar Fuel Door
Rubicon Shocks
18/59 Springs
Bestop Mats
acopper123 is offline
post #2 of 14 Old 08-01-2014, 01:27 PM
kjeeper10's Avatar
Sounds extensive. Take this and see what you get for height Name:  ImageUploadedByAutoGuide1406921247.956434.jpg
Are you sure nothing is loose ?
Sent from AutoGuide.com App
kjeeper10 is offline
post #3 of 14 Old 08-01-2014, 01:43 PM
Thanks!
Have you straightened the steering wheel back out by turning the turnbuckle on the drag link yet? Make sure everything has been loosened and then retorqued with the Jeep on the ground.
RK 2.5 Triple Rate Coils, MC control arms, 40" Trail Grapplers.
Terminator2 is offline
post #4 of 14 Old 08-01-2014, 01:59 PM Thread Starter
acopper123's Avatar
I hate to admit this, but I had the install done at the dealership. They did it cheap, but somebody missed something apparently. My steering wheel now sits at 11 o'clock to go straight, and the wheel is ridiculously loose. There's no responsiveness at all. They tell me this should be just a basic swap, but I'm getting pretty severe wobble occasionally just before hitting 60mph.
acopper123
Mopar Fuel Door
Rubicon Shocks
18/59 Springs
Bestop Mats
post #5 of 14 Old 08-01-2014, 02:28 PM
Yikes. They may have left the track bar loose up front or maybe they left a control arm bolt or two loose as well. Check all the bolts they need to be loosened then retorqued to 125 ft lbs (upper control arms bolts in front can be 85 ft lbs). Loosen the 2 15mm nuts on the drag link turn buckle and have someone sit in the jeep and turn the turnbuckle by hand it until the wheel is closer to 12:00 to go straight. Then tighten the 2 15mm nuts and go drive it and then readjust until it is dead straight which may take a few tries.
post #6 of 14 Old 08-01-2014, 02:44 PM
A JKO DICK
ASSFROW's Avatar
Sounds like they left the turnbuckle loose on the drag link. There is no reason for it to have changed much at all unless the ball joints went to shit from the wheels dangling in the air when it was lifted or they left something loose. Your caster is a little worse than before, but should not be that extreme. Decreased caster will cause flighty steering, but again you should barely notice it.
ASSFROW is offline
post #7 of 14 Old 08-01-2014, 02:45 PM
gold knight's Avatar
x3
Something has to be loose or disconnected. I did a 2 1/2" budget boost a while back and it didn't need to do any adjust at all to get the steering wheel straight afterward.
STOP DRIVING UNTIL YOU FIND WHAT IS LOOSE!
gold knight is offline
post #8 of 14 Old 08-01-2014, 02:45 PM Thread Starter
acopper123's Avatar
Terminator2.... thanks a million! That's exactly what the issue was. They had put the flag-nut on the wrong side so it wasn't catching and came loose within about 10 miles. And to think... I took it in there to save time and assumed they could get an easy swap done right! They didn't seem thrilled that I was telling them what to do from advise off of a forum! Haha...
Thanks!
acopper123
Mopar Fuel Door
Rubicon Shocks
18/59 Springs
Bestop Mats
post #9 of 14 Old 08-01-2014, 02:47 PM
....They didn't seem thrilled that I was telling them what to do from advise off of a forum! Haha...
Thanks!
lol
Glad you got it straight.
post #10 of 14 Old 08-01-2014, 02:54 PM Thread Starter
acopper123's Avatar
Assfrow... Talk to me a little about castor. Rememer- I'm an idiot with this stuff at this point! Is that something that I need to correct or compensate for? Am I going to experience increased wear somewhere from what I assumed was just a cheap/quick mod? Love my basic rig, but I can't justify dumping a ton of cash into a JK with a mini-van motor.
Thanks all.... you guys nailed it.
acopper123
Mopar Fuel Door
Rubicon Shocks
18/59 Springs
Bestop Mats
post #11 of 14 Old 08-01-2014, 02:59 PM
You lost only around 1/2* or so of caster with those springs which you will barely notice.
post #12 of 14 Old 08-01-2014, 03:17 PM
kjeeper10's Avatar
The track bar was loose ?
post #13 of 14 Old 08-01-2014, 03:41 PM Thread Starter
acopper123's Avatar
Yes. They put the flagged nut on the opposite side (so I'm told) causing the track bar to come loose. I took it back that was corrected. They also straightened out the steering wheel as explained to me above. Afterward the steering ranges were normal, the "wobble" disappeared, and there was no longer any "play" in the feel of the steering.
acopper123
Mopar Fuel Door
Rubicon Shocks
18/59 Springs
Bestop Mats
post #14 of 14 Old 08-01-2014, 04:21 PM
kjeeper10's Avatar
There's only a flag on the axle side ?
Which would be impossible to reverse the bolt (in from other side)
I think they just left it loose. Very good thing you did not experience full blown death wobble,
