Any idea if this will fit? I know it's not ideal but I have access to skid steer trailer but it's only 14' +2' trailer. I'm not too worried about the weight distribution it's a solid trailer truck has bags. Just know it will be tight. But would rather go in the truck for 8 hours than the Jeep. Any thoughts would be greatly appreciated.
I had one like that, 10k lb rated Top Hat, that I used to haul my built YJ with. Heavy (2,500lbs) even with a wood deck, but I had diesels at the time that handled it fine. Took it to Tahoe & back from Colorado to run the Rubicon, many other trips, never missed a beat. The load sits high on them which annoys some guys. They need very good tires, don't skrimp. Make sure it has good brakes, too. Provided the deck is wide enough a JK will fit just fine. I got the one I had because it was the only trailer I could find locally that was wide enough for the YJ.
