Let's see your grill mesh.... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 07-28-2014, 06:03 PM Thread Starter
SoK66's Avatar
I knew this was going to happen, but did I listen to myself? Of course not. Long ago I told myself to install some mesh behind the grill, but NO. Took the Short Bus into town with rain threatening. On the way back it went from threatening to Noah's flood, which turned into a pea-size hail monsoon. Got it home & into the garage. No body or glass damage, but the hail knocked the shit out of my new Mopar trans cooler's fins and the exposed ones on A/C condenser. No ATF leaks I can see and A/C performance appears to be fine. "Grille mesh" is right there on the wish list...at the bottom...behind a tailgate table...
So, ok, who sells the best behind the grill mesh?
SoK66 is offline
post #2 of 19 Old 07-28-2014, 06:13 PM
re:Let's see your grill mesh....
re: Who sells the best grill mesh for a JK?
Home Depot ...
<< http://tinyurl.com/qgatvsu >> + <<
http://tinyurl.com/p9u8srb>> + <<
http://preview.tinyurl.com/pvc2xy3>> + some cable ties = done.
post #3 of 19 Old 07-28-2014, 07:06 PM
^^ Yep. Most of the stuff on the market is way too damn expensive. Rain gutter stuff from home depot.
post #4 of 19 Old 07-29-2014, 01:25 AM
Gojo03's Avatar
Gutter guards, sticky tabs and zipties, all from Lowe's
Gojo03 is offline
post #5 of 19 Old 07-29-2014, 01:51 AM
Ebay - Chinese 3D style insert...free postage, and heaps cheaper than the name brands.
required a little bit of grinding around the edges to fit properly, and the 3D pressed shape is a touch off.....but not enough to really notice.
It'll stop rocks, which was my main reason for buying it.
LeighP is offline
post #6 of 19 Old 07-29-2014, 01:56 AM
UnlimiDozer's Avatar
OK, been thinking about this myself. The gutter guard idea makes a lot of sense. Is that stuff metal or plastic?
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #7 of 19 Old 07-29-2014, 02:01 AM
Gojo03's Avatar
metal. I cut mine down with tin snips then painted.
Gojo03 is offline
post #8 of 19 Old 07-29-2014, 08:22 AM Thread Starter
SoK66's Avatar
Thanks for the tips everyone, giving me some ideas.
A question for you Gutter Guard guys, is the plastic gutter guard stuff available in widths wide enough to do just one piece, rather than seven narrow ones?
SoK66 is offline
post #9 of 19 Old 07-29-2014, 08:31 AM
I don't think the plastic stuff would do as good of a job of stopping rocks.
post #10 of 19 Old 07-29-2014, 08:59 AM
Gojo03's Avatar
I don't know about the plastic stuff. I guess if you find the right size and a pattern you like you could use anything. I picked the metal. I used 7 pieces for the slats and basically 1 piece for the skid
Gojo03 is offline
post #11 of 19 Old 07-29-2014, 01:34 PM
Send a message via Skype™ to jlagross
i used diamond lath and bedliner. works great. did 3 jeeps for 20 bucks.
comes in a 4x8 sheet. cant post pictures from work computer , but looks natural also.
jlagross is offline
post #12 of 19 Old 07-29-2014, 04:45 PM
I need to get this done. I have always wondered about the large grill openings! Better safe then sorry.
mforce is offline
post #13 of 19 Old 07-29-2014, 05:28 PM
membrain's Avatar
Someone say grill pictures?
2010 Red Unlimited Rubicon 6 speed - Traded!
2014 Red Unlimited Rubicon X 6 speed - starting over!
membrain is offline
post #14 of 19 Old 07-29-2014, 07:43 PM
gnarlyswine's Avatar
Single piece of aluminum mesh. About $20 from a metal shop. Cut and bent it to shape. Attached to radiator, not grill. More functional and durable than plastic mesh.
This is three years old.
Unspoilt by progress.
gnarlyswine is offline
post #15 of 19 Old 07-29-2014, 07:50 PM
see , I am sure you guys all relate, but I have weighed the same buck-fifty /buck-fifty-five since 10th grade and I am in my forties; I mention this because I had NEVER considered weight nor anything re: "saving" weight - I'm not unlike an OCD ,point-of-heaviness-seeking monster - until I bought my JK. Yes, we are talking a matter of ounces in weight between plstic and tin/aluminum gutter guard but I went with the plastic you see in that post up there. I have, literally, hit a blue-jay at 45mph and had feathers (purdy blue ones!*) lodged into that stuff as well as rocks, mud, grain from cattle trucks, more rocks, cig butts from arseholes in front of me and my 8 year-olds 12/6 curveball all smash into my plastic grill inserts. I even poked them with a 17mm box wrench after all that 'cause I was shocked at the way GORILLA GLUE EPOXY will , simply, hold freaking anything. The cable tie 1"x1" mounts that we are talking about? they have adhesive on back; fit perfect between the grill slats ( there are several detailed write-ups on here and 'elsewhere' ) and if you are wise, ya already know not to buy any cable-ties that arent advertising the weight load they can bear on the packaging ( UV safe & mil-Spec only) so....slap the strips ya cut down , cabletie-lashed to the mounts and before you smoosh the little bungs or whatever they're called , smack a dollop of epoxy between the grill and the tab mount and then let it dry for a few hours in the sun. It wont ever go ANYWHERE....I imagine these plastic rain gutter guards that weigh ever so little less than the metal ones will outlast my scrawny behind on this earth.....unless we fall into the Sun and melt....I'd say it's a personal preference but I will always go with lighter stuff like everything else on my JK pig....aluminum-nom-nom-nom.......cause that's just how I roll.....
wow, i said that, didnt I?
heh.
so, to answer; get whichever, just mount it right and fahgitabbahdit....
(* I love animals. I begged the dude to not smash into my grill as it occured but it seems Deer, rabbits, opossums, armadillo, squirrels and other small critters like to smash into my winch or my Jeep ....for the PETA folks, I saved the feather and made sure the Jay was dead and not in misery when I stopped and peeled it off the 35" ,10 ply cooper STT it wound up stuck to after it fell from the grill.... see? I am nice to animals!)
post #16 of 19 Old 07-30-2014, 02:18 AM
here's how i mounted mine. followed up with final look.
idriv442 is offline
post #17 of 19 Old 07-31-2014, 06:43 AM
re: Let's see your grill mesh....
shweet; love the orange. Nice job!
post #18 of 19 Old 08-03-2014, 09:23 AM Thread Starter
SoK66's Avatar
Ok, I settled this last week by swallowing hard and ponying up stupid money for a T-Rex 3D billet mesh from Q-Tec. I didn't want to hassle with home-built stuff cuz time is tight and I'd probably butt-boy the install anyway. (Patience is not a skill set around here.) So, ordered the thing and got it like two days later. Impressive materials, quality built, pretty simple install. Lower outer mounting tabs didn't line up as they said, so I just found some smaller speed nuts in my nut & bolt bins and put them on the outside of the grill mount tabs. The stuff is very stiff, which made the grill a bit more dificult to snap back into place but not a curse-inducer. Nice finished product. The 3D feature fit the grill slots perfectly, and the mesh is tight along the entire length of the plastic grill.
So, now that the horse is out of the barn and my trans cooler fins are all bollocked with nicks I feel so mch better....although my fellow club members will never let me live this down....
Thanks for the tips all!
SoK66 is offline
post #19 of 19 Old 08-06-2014, 02:05 AM
zin
Has anyone done a write up on there install. I like the looks of the "home made" ones but I'm not sure where to mount to. Of corse I've never popes the grill and once I do it may be self explanatory
2014 JKUR 6 speed, grab handels, trunk. JCR full with bumper, warn zeon 10-s on its way. More to come as the wife lets me
zin is offline
