3.5" lift on 35s... too small??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 07-27-2014, 02:17 AM Thread Starter
Well let me start off that I recently purchased my very 1st Jeep, 2014 JK Unlimited. I'm planning on getting a 3.5" RK xfactor lift My worries are if 35s would look to small on a 3.5" lift. I want to give my Jeep a beefier more aggressive appearance. What do you guys think of 35s on a 3.5 lift? Or should I for a 2.5 lift
jeepboy_714 is offline
post #2 of 25 Old 07-27-2014, 03:33 AM
Gojo03's Avatar
I have 35s/2.5" right now. I like it, but have seen 35s/3.5 and they look good too
Gojo03 is offline
post #3 of 25 Old 07-27-2014, 03:44 AM
kjeeper10's Avatar
Not at all ..
Sent from AutoGuide.com App
kjeeper10 is offline
post #4 of 25 Old 07-27-2014, 06:23 AM
Stock flares it will look fine with 3.5" lift but if you cut the flares it is going to make your 35s look like 31s so stay stock flares or get at least 37s.
Terminator2 is offline
post #5 of 25 Old 07-27-2014, 06:50 AM
kjeeper10's Avatar
Um Name:  ImageUploadedByAutoGuide1406465418.633293.jpg
post #6 of 25 Old 07-27-2014, 07:52 AM
tapcola's Avatar
I love the way mine looks ! how ever I am planning on going to 37 !
tapcola is offline
post #7 of 25 Old 07-27-2014, 07:55 AM
tapcola's Avatar
Holy crap ! big picture
tapcola is offline
post #8 of 25 Old 07-27-2014, 08:42 AM
3" with 35s and flat fender flares
annerj is offline
post #9 of 25 Old 07-27-2014, 09:37 AM
MrBreeze's Avatar
Location: Cave Creek, AZ to Fayetteville, AR, back to Scottsdale, AZ
The idea as to what "looks good" is subjective and there are a lot of pics of rigs with different lift/wheel/fender combos - take a look at a lot of pics and do what ever you think looks good to you. With that said, you asked for opinions, so here's what I've run on my JKU and my impressions:
Started with an AEV 2.5" lift on 35's and stock fenders - looked good, no rubbing.
Then went to Poison Spyder aluminum fenders with the 2.5" and 35's - looked better, no rubbing.
Moved up to a 4.5" lift (3.5" Rock Krawler X Factor with 1" spacers) - the 35's look a bit small in the wheel wells, but my plan is to go with 37's.
MrBreeze is offline
post #10 of 25 Old 07-27-2014, 11:39 AM
leman's Avatar
I think it will look good. right now I'm on 2.5" with 35"s and it performs pretty good and drives great, but getting tired of dragging my belly over everything so I'm stepping up to the 3.5" RK. Ill be running my 35"s till they are done then step to 37"s
2008 steel blue sahara
with some doo-dads
leman is offline
post #11 of 25 Old 07-27-2014, 01:58 PM
Poormanz28's Avatar
Another pic. I got basically that setup. Check my sig and photo album. Mud is my biggest concern, not rocks. I need higher RPM. I think going bigger than 35 in the mud would be bad with my 3.8L. If I had a 3.6L I would be all over 37's.
2008 Jeep JK Unlimited. Auto. Mods: 3.5 RK Max Travel Kit, RK tie rod. 35" Nitto Trail Grappers. Eaton 4 Pinion E-Lockers front and rear. Nitro 30 spline chrome moly front axles. Yukon 5.13 gears/Cyrotreated. Sleeved and gusseted front axle. Dynatrac ball joints. Mopar big brake kit, Advance Adaptors 4wd shift linkage, Tom Woods front and rear driveshaft. Ace Rock Sliders. Terra Flex hinged tire carrier, Carolina Metal Masters grab bars. Exp One Frt Bumper. Warn Zeon 12 Winch.
Poormanz28 is offline
post #12 of 25 Old 07-27-2014, 02:24 PM
Are you a 4 door or 2 door?
post #13 of 25 Old 07-27-2014, 02:43 PM
leman's Avatar
4 door. this happened way too often.
with some doo-dads
leman is offline
post #14 of 25 Old 07-27-2014, 04:49 PM
The 3.5 coils and 40s will fix this.
post #15 of 25 Old 07-27-2014, 06:26 PM
Originally Posted by kjeeper10 View Post
You heard me you need bigger tires now that you cut your flares.
post #16 of 25 Old 07-27-2014, 06:39 PM
kjeeper10's Avatar
Thought surely has crossed my mind.
post #17 of 25 Old 07-29-2014, 04:48 PM
I like the 3.5 with 35's because once you add armor your will lose some height which will allow the 35's to look fine IMO.
mforce is offline
post #18 of 25 Old 07-29-2014, 05:46 PM
2Door's Avatar
Plus, being a 4 Door, your Jeep weighs a little more than a comparable 2 Door. I'd say 3.5" lift, 35's and any flares on a 4 door is awesome.
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #19 of 25 Old 07-29-2014, 06:16 PM
This was my last Jeep. 3.5" AEV lift; 35" tires.
MOPWR2U is offline
post #20 of 25 Old 07-30-2014, 09:40 AM
Here is my 2.5 in lift with 33's soon to be 35's
Rob,
2012 Jeep Wrangler Unlimited 4 Door
2.5 in Lift
4.56 gears
Wild Country MTX 285/70R17
Much, Much more to come!!!
DCT1964 is offline
post #21 of 25 Old 07-30-2014, 11:23 AM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
That is how we roll!
Personally, I like 2.5" for 35's. Or even the 1.5" but that is just me!
If we can help, let us know! Welcome to the forum and to your first JK!
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
post #22 of 25 Old 07-30-2014, 11:31 AM
Personally, 35 with OEM fenders and 35's look good and offer a lot of functionality. If, down the road you decide to go to flat fenders, you can even make the jump to 38's...
Good luck with you build and thank you for choosing RK...
RK
post #23 of 25 Old 07-30-2014, 02:54 PM
leman's Avatar
I keep bouncing back and forth between staying with 2.5" and going up to 3.5" I dont really want to be any higher, but its so frustrating getting the belly of the JKU hung up on break over angles. or have that one rock that you just spin like a top on top of.
with some doo-dads
leman is offline
post #24 of 25 Old 07-30-2014, 04:01 PM
3.5s and 40s to the rescue. That would give you 3.5" more belly and 2.5" more axle clearance vs what you have now. It will still be plenty stable.
RK 2.5 Triple Rate Coils, MC control arms, 40" Trail Grapplers.
post #25 of 25 Old 07-30-2014, 04:11 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
3.5 X-Factor and 35s on this one:
Marcus
RiverCityOffroad is offline
