Doors when removed.... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 05-05-2014, 10:00 AM Thread Starter
What do you guys do with your doors when you take them off the Jeep to prevent them from being damaged? I was thinking of designing a rack to hold all four doors in CAD. Something that I could roll around my Jeep easily and would store the doors in an upright position. Gonna use tubes off a laser burnt base plate with foam pool noodles to keep from scratching the paint. Just wondering if a rack like this already exists and what others are doing when they take their doors off.
I attached a concept of what I'm thinking. Still gotta take dimensions off the doors though.
Blucotech is offline
post #2 of 12 Old 05-05-2014, 10:04 AM
Slow and Low
Co4Lo's Avatar
I just sell mine after I take them off.
Co4Lo is offline
post #3 of 12 Old 05-05-2014, 10:04 AM
StubEXrube's Avatar
I set 'em in my garage on a few pieces of cardboard to keep 'em off the floor and sometimes throw a couple old t-shirts over the top to keep them from getting scuffed against the walls.
StubEXrube is offline
post #4 of 12 Old 05-05-2014, 10:42 AM
damon.l's Avatar
I havnt done anything but set them on the floor, drop them on the floor, bend some of the edges... ya. don't really care.
damon.l is offline
post #5 of 12 Old 05-05-2014, 10:43 AM
hang em on the wall out of the way.
post #6 of 12 Old 05-05-2014, 11:03 AM
Same here. The brackets can be found at Lowes for under $20.
texasmike74 is offline
post #7 of 12 Old 05-05-2014, 11:14 AM
then you can run a bungee with a spring clamp and hold the side windows up as well.
post #8 of 12 Old 05-05-2014, 12:45 PM
I bought the Plates that mount on the wall for hanging them off their hinges.
Still havn't mounted them on the wall yet.(Year later) Hopefully in the next couple of weeks. Ace makes them.
Alaska-HWY JK is offline
post #9 of 12 Old 05-05-2014, 12:50 PM
JKO Dickhead
Asmmns's Avatar
O have seen something similar advertised in a catalog I got... don't recall if it was quadratec or 4WD
__________________
CURE SMA !
Asmmns is offline
post #10 of 12 Old 05-05-2014, 12:53 PM
camo36's Avatar
I use similar to the brackets above. Except I just used the some white 10"x12" L-Brackets for shelving (even cheaper than the ones above) then put plumbing insulation on them and screwed them fast to the wall. didnt even use wood to mount them to the wall. Just drywall anchors.
'64 CJ-5, '74 Bronco, '79 CJ-7, '84 CJ-7, '92 XJ, '96 XJ, '99 XJ, '01 TJ, '01 XJ, 2013 JKU.
2013 Commando Green JKU
35x12.50/17 Falken Rocky Moutain ATS
2.5 RK X-Factor
17" Black Rock Vipers
Cut Stock Flares
Diablo Sport Trinity (garbage)
Sleeve, Truss, ARB, Chromo D30
camo36 is offline
post #11 of 12 Old 05-05-2014, 12:56 PM
BigMike's Avatar
Mine are on the floor on towels in the garage. But I'm going to get a set of these for my 2 door. Below is a link to the 4 door hangers.
http://www.aceengineeringandfab.com/...gers_p_38.html
, Granite,
BigMike is offline
post #12 of 12 Old 05-05-2014, 01:04 PM
I forgot I paid that much. I better get a streak of ambition and mount them.
