35s no axle upgrades - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 04-29-2014, 04:25 PM Thread Starter
Anyone running 35s without doing any upgrades to the front axle?
sdub is offline
post #2 of 13 Old 04-29-2014, 04:30 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
You'll be fine for daily driving. If you're planning on wheeling a bit get some c-gussets ($65) welded in and go have fun. You could go all out with a truss at the same time ($100) but it isn't 100% necessary just to bolt them on and feel good about your ride.
Marcus
RiverCityOffroad is offline
post #3 of 13 Old 04-29-2014, 04:41 PM Thread Starter
I use mine as a daily driver. I hear all these claims that even a pot hole can bend thr Cs.
sdub is offline
post #4 of 13 Old 04-29-2014, 04:57 PM
RockR8r 4x4's Avatar
C-gussets are inexpensive and don't take long to burn in. Why not get them?
That being said, Marcus is correct. None of that is NEEDED. I think the weakness of the D30 is widely exaggerated. However, if you do bend a C, then that sucks.
-Dan
PM me for a quote
RockR8r 4x4 is offline
post #5 of 13 Old 04-29-2014, 04:58 PM
Lots of fear mongering on the internet. My personal opinion is that it takes a lot to actually bend one. If you're daily driving the thing just put the tires on there and enjoy it. The odds of you actually having a problem are slim until you're beating on it offroad, winching against a wheel that's in a bind, ect. You're not likely to bend the axle by daily driving it.
Marcus
post #6 of 13 Old 04-29-2014, 05:14 PM Thread Starter
Thanks for the info guys.
sdub is offline
post #7 of 13 Old 04-29-2014, 05:27 PM
tiltz's Avatar
I wheel pretty frequently with a couple of guys for the last 2 years or so that have 35s and have done nothing to their axles. They haven't broken anything. The axles might be bent, but not noticeably.
There are also 2 guys in my group that have been/broken sleeved 44s on 37s.
I built my axle with sleeves and a truss to be on the safe side and it is holding up well on 37s.
tiltz is offline
post #8 of 13 Old 04-29-2014, 06:04 PM
GSLSE21B's Avatar
i ran 40s on a stock d30 and 44 for years ... only things that broke were driveshafts
GSLSE21B is offline
post #9 of 13 Old 04-29-2014, 08:54 PM
I got through these days where I think I'm rich. So I got my D44 trussed and Cs gusseted. I guess I could have spent it on Crack and Hoes or Crackhoes, so I'm fine with it. The gussets are a must, in my opinion. The truss (labor) is expensive so if you don't do it yourself, maybe save the money.
I was not serious about the other options above.
2014 JKUR White+white+white
Flyer is offline
post #10 of 13 Old 05-01-2014, 06:52 AM
It is cheap insurance to weld the gussetts, why wouldn't you? Why risk a several thousand dollar axle for a 200 dollar job? Seems like a no brainer to me.
fp8950 is offline
post #11 of 13 Old 05-01-2014, 07:01 AM
M&M's's Avatar
Yes you should deff at the least sleeve your shaft when using crackhoe's fo sho.....
35's in my book constitute a commitment to upgrading other parts as well with C-gussets being the first thing. If your not going to install a truss but you do plan on wheeling it at least get the Nitro drive in sleeves. Again, cheap insurance and very easy to install with a couple buddies on the weekend. Just wait to start drinking till after the sleeves are driven in cause everyone's aim may be a little sketchy...
Oh and the gussets can be installed with the axle in place. Just remember to stitch them in and don't overheat your bj's in the process.
Originally Posted by van7559
I can bury my pinky in the rear, and just barley feel it, the front is a little easier, but still seems low to me!
I fist fuck life with a nuclear powered pneumatic fuck hammer for 60, 70 hrs a week...
M&M's is offline
post #12 of 13 Old 05-01-2014, 07:43 AM
If he stuffs the axle he can upgrade to a PR44 or a junkyard 60... and clearing that 60 will require 37's... which will make hydro assist attractive... and then he will be set for 40's.
So I see at least three if not four reasons not to gusset. New axle, 37's, hydro, 40's... And yes I am joking. Sort of.
Nomad_K is offline
post #13 of 13 Old 05-03-2014, 09:42 AM
jtphoto JK's Avatar
My thoughts exactly. Don't waste time on the D30. Run it, then if/ when you have a problem upgrade to a Dynatrac or Prorock.
Jeff _(OllllllO)_
jtphoto JK is offline
