Another ClockSpring Bites the dust - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 04-20-2014, 10:06 AM Thread Starter
dmhines's Avatar
Light came on a couple of months ago. I have 55K miles on my 2009 JK.
I went into dealer for an oil change and 5 Year Life-Time Warranty inspection.
I told them about ABS light and they diagnosed it as ClockSpring of course. I had them call Jeep .. but Jeep said they would not help cover repair cost. Dealer said they would do repair - parts and Labor for $320 ... I told them go for it - the AIRBAG light is super bright and dead center of the cluster - very annoying.
When I got home last night I filed a report with the NHTSA like everyone else is doing. I also sent Email to Jeep Customer service saying Dealer found OPEN CIRCUIT on Driver AirBag and airbag would not have have deployed in an accident so I HAD to repair it. I then asked to be compensated for the repair. I will see how that goes.
Also .. this is a mod friendly dealer ... My JK passed the 5 year inspection with flying colors.
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline
post #2 of 13 Old 04-20-2014, 11:20 AM
TCdawg's Avatar
Mine went out last month Dan. Swapped it out myself, easy swap. Got the clockspring online for $205 shipped. I'm with you, that ABS light is right in the middle of the dash and mine was dining every 2 or 3 minutes, sometimes, driving me crazy.
Good luck getting your money back, hope you do.
TC
TCdawg is offline
post #3 of 13 Old 04-20-2014, 09:09 PM
HOGGSTATUS's Avatar
I got mine fixed under warranty at 69k, it went bad again less then 7k later!! My buddy just repositioned it and no lights on the dash! Only thing that doesn't work is the horn....VERY ANNOYING!!
"CUTTS CREW"
"08 2 Door X-Fox Coilovers-Custom MC ended Long Arm w/ 8" Rear Stretch-40" ProComp MT2-ProRock 44 Unlimited-ARB Front/Rear Locker-5.13's-Custom VKS Rock Rails-Chopped Fenders-ARB Compressor-Overkill Corners Customized-PSC Hood Louver-PSC BFH Trail Stinger
HOGGSTATUS is offline
post #4 of 13 Old 04-20-2014, 09:47 PM
Clock spring.
Mine went out a week before leaving for EJS. 2007's are warrantied 10 years, 150,000 miles.
Alaska-HWY JK is offline
post #5 of 13 Old 04-21-2014, 05:16 AM Thread Starter
dmhines's Avatar
I assume you had purchased an extended warranty?
dmhines is offline
post #6 of 13 Old 04-21-2014, 06:27 AM
HOGGSTATUS's Avatar
Yes....due to financing the Jeep.
"CUTTS CREW"
post #7 of 13 Old 04-21-2014, 09:16 AM
jason mac's Avatar
The more I see these clock springs popping I see it is a lot of 2 doors. Then I checked my 2 door versus a 4 door and it seems the 2 door steering wheel turns 1 3/4 times to the 4 door that turns 1 1/2 times from center to lock. Thinking maybe it's the extra 1/4 turn that is stressing these things.
jason mac is offline
post #8 of 13 Old 04-21-2014, 09:33 AM
Jaybee1669's Avatar
It sounds like someone didn't pull the wiring harness free from the clock spring before pulling the wheel.
Pull the center cover off of the wheel. takes a few minutes with a 90degree pick tool. Dsiconnect the 2 wiring harnesses from the airbag module. You'll see 4 pressure switches wired in parallel in the steering wheel, from what i can tell, all four must make contact for the horn to work properly. Check the wiring, i'm sure on of them is broken.
A good write up for it here: https://www.jkowners.com/forum/showthread.php?t=92336
Jaybee1669 is offline
post #9 of 13 Old 04-21-2014, 08:30 PM
I just had mine replaced by the local dealer no questions asked. 55k miles.
2007 4 door.
Fixerupper is offline
post #10 of 13 Old 04-23-2014, 07:53 PM
From what I understand if something is replaced under warranty it extends that part for another year plus 12,000 miles, or at least that has been my experience I've had.
2012 Jeep Unlimited Rubicon Gecko Green!
6" longarm, 40" tires, 4:88's Synergy inner/outer sleeves, trussed, c's and hvy duty ball joints,Tom Woods DS f/r, Bush Whacker Flat Fenders.
RSE Rear Bumper, Smitty Stinger front.
ShizNizy is offline
post #11 of 13 Old 04-23-2014, 07:59 PM
ADDICTION II build begins....
TXROCK's Avatar
sounds like time for an AIR HORN upgrade!
https://www.facebook.com/photo.php?v...58168615879415
https://scontent-a-lax.xx.fbcdn.net/...89&oe=5358927F
U.S. Army
TXROCK is offline
post #12 of 13 Old 04-23-2014, 08:17 PM
HOGGSTATUS's Avatar
Originally Posted by TXROCK View Post
I like it!!
"CUTTS CREW"
post #13 of 13 Old 04-23-2014, 08:29 PM
TXROCK's Avatar
I like it!!
Kleinn 101 train horns directly hosed off of the Viair 400C air compressor through the Dominion Off-Road OBA hose tray, and powered through the factory horn wires.
U.S. Army
TXROCK is offline
