2014 Rubicon X traildash install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 04-13-2014, 09:30 PM Thread Starter
Hi all, just got my 2014 Unlimited Rubicon X a week ago. First thing I ordered was the new Superchips Traildash because it is supposed to work with the 14's now. First thing I do is go to the superchips site and download the update program for the Traildash and make sure it is up to date. Next I go to install it and the first thing it tells me is that it does not recognize the programming for my Jeep. It then copies my programming to the traildash and pops up the programmer dash. It definitely recognizes I have a rubicon because of the dash layout, but will not give me any power program options. It also reset my TPMS system and all I see is zero's now. Another thing it is doing is when I start the engine it gives a electronic stability control dash light and the air blows hot no matter what the thermostat is set to. I shut the engine off and remover the plug to the obdII port and everything is normal. Has anybody had similar issues? I am calling superchips in the AM to see if there is anything they can do.
jeffmiller1990 is offline
post #2 of 9 Old 04-14-2014, 08:35 AM
They are still working on the '11 up programming..
CT Performance, Inc is offline
post #3 of 9 Old 04-14-2014, 01:34 PM
I've had the TrailDash installed on my 14JKUR for about a month and haven't seen these issues (I've tried two of the tunes so far). For the TPMS to be disabled, an unlock code is needed (simply request and they provide it). I'm not sure why that would be jacked up, but I'd work with their tech to resolve your issue...it seems it didn't load the program properly.
14JKUR is offline
post #4 of 9 Old 04-14-2014, 01:43 PM
Good to hear....just must be my '11 that's a issue...or all the '11's as they are the bastard child...
post #5 of 9 Old 04-14-2014, 02:26 PM
ratchettt's Avatar
I have had the SuperChips Flashpac since Nov 2013. They still have not resolved my TPMS problems. Many calls. Always, "will advise the engineers." I had to rig my true tire size to get accurate MPH after going to 35's(34.5 actual). Memory is I had to set by trial and error to 33.5.
Things work for some and not for others. You and I are Others.
My advice is return all settings to factory, then return the unit under their 30-day satisfaction guarantee.
2013 JKR, Auto, Yukon 4.56, Goodyear MTR/K 35/12.5/17 on XD222 KMC Enduro Beadlocks,Teraflex Big Brakes & Spare Carrier, Warn RC Winch, Metalcloak Front & Rear Bumpers, Metalcloak Overliner Flares & Front Inner Fenders w/ Corner Guards/Tail Lamps, Metalcloak Game Changer 2.5" w/6-Pac's, ARB Diff Covers & Onboard Air, AFE High Tuck Muffler, Front Lower Control Arm Skids, Artec Aluminum Skid System, Poison Spyder Hood Vents, Ripp SC.
There are no winners here; just beguiled participants
ratchettt is offline
post #6 of 9 Old 04-14-2014, 07:14 PM Thread Starter
Superchips Tech Support
Well, I gave tech support a call this morning and they set my account up to log all the files from my traildash so they can work the issue. The A/C problem and the ECS disabling itself may have been due to me not turning the ignition off and then restarting after installing the unit because I'm not having that issue any more. I still don't have the ability to tune the ECM though.
post #7 of 9 Old 04-30-2014, 04:39 PM Thread Starter
Okay, new update on my traildash install. After getting a new firmware update from superchips I installed the traildash again and behold...I finally got the options to tune my pcm. That's where the trouble began. I picked the 87 octane tune and started the process. The tuner got stuck in a cycle of tuning over and over again. Of course now I can't even start the jeep. After a call to superchips I sent my PCM out of the Rubi and the traildash back to them to get things fixed, hopefully. Everything is overnight so hopefully Friday i'll have a running Jeep again.
post #8 of 9 Old 05-01-2014, 07:01 AM
ratchettt's Avatar
One more time
One more time.
post #9 of 9 Old 05-09-2014, 09:36 PM Thread Starter
Well, got my PCM back from superchips and installed it. Jeep runs again!! I quickly boxed up the traildash and sent it back to quadratec. Don't think i'll be trying that again anytime soon. I'm not doing any mods at the moment that need me to update my speedo or tire pressure limits anyways.
