procal question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-10-2014, 05:35 PM Thread Starter
procal question
what needs to be done first with a procal when i adjust my jeep to the new 4.88's and 33's? ive read you need to center the wheels first, and let it read the vin. i just plugged it in for 4.88's and its shifting sooner? doesnt make sense as i was told by several people who sell and have them that itll set the trans to shift at a higher rpm. did i do something wrong?
MI JeepSkate is offline
post #2 of 5 Old 04-10-2014, 06:09 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Double and triple check your dip switches. Maybe you set the tire size too small by mistake?
JKCTAZ is offline
post #3 of 5 Old 04-10-2014, 06:31 PM
TRAUMAhead's Avatar
I tried messing with the gearing options on the ProCal trying to get the JK to shift later and found it barely made a difference when I ran 4:10s and now 5.38s on 35s. Tried the lowest (3.21 think?) and highest 5.86, and the RPM shift range only changed by a couple hundred.
TRAUMAhead is offline
post #4 of 5 Old 04-12-2014, 05:08 PM Thread Starter
My DA forgot to program the 33's in the computer....... lol. ill se how it does tomorrow or monday. thanks for the tip!
post #5 of 5 Old 04-12-2014, 07:24 PM
SoK66's Avatar
Yep, do the tire size first, then the gear ratio. Don;t plug in the advertise tire size, set your pressures to street level, then measure from ground to the top of the tire. Plug that numer into the Procal.
SoK66 is offline
