I need New Tie Rod and Drag link??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 04-03-2014, 11:58 AM Thread Starter
azrockzuk's Avatar
What is your options on :
I just ordered the Pro Rock 44 from Dynatrac as I keep cracking the stock rubicon front housing...
I do have the red neck ram set up as well...I have it welded to the diff. cover now.. but I can not weld to the cast Diff cover on the new Axle.. Any suggestions???
I have the short arm taraflex 4inch-ish now with coil overs in the front...
Time for a upgrade...(I have the stock set up Now)
What is a good tie rod and drag link to go with??? Flip???
Thanks for your input!!!!
Chad
azrockzuk is offline
post #2 of 7 Old 04-03-2014, 01:54 PM
tiltz's Avatar
Synergy... for ease of use, price, quality and reputation
I am also a fan of the home built aluminum tie rod
tiltz is offline
post #3 of 7 Old 04-03-2014, 02:17 PM
A JKO DICK
ASSFROW's Avatar
RK aluminum tie rod. Synergy drag link and track bar. Flip it!!
ASSFROW is offline
post #4 of 7 Old 04-03-2014, 03:20 PM
Assfrow
All of our new stuff is available now as well as a new and improved track bar bracket for the axle connection so anyone's track bar will work with it and a one piece track bar relocation bracket. Our system images will be out soon...
OP
Cool color...
RK
post #5 of 7 Old 04-03-2014, 03:36 PM
ALASHA's Avatar
Rock Krawler aluminum drag link and tie rod with the new ridiculously large joints. As for the ram mount, build you own. That is what I ended up doing:
https://www.jkowners.com/forum/showpo...05&postcount=2
ALASHA is offline
post #6 of 7 Old 04-03-2014, 04:45 PM
A JKO DICK
ASSFROW's Avatar
Originally Posted by Rock Krawler Suspension View Post
Assfrow
OP
Cool color...
RK
Will the track bar work with a sector shaft brace?
Maybe you should toss some my way to test out!
So there's an RK aluminum drag link? What about the tie rod?
ASSFROW is offline
post #7 of 7 Old 04-03-2014, 05:10 PM
kjeeper10's Avatar
Full out RK VS Synergy go ... Ha!!
RK's new stuff is looking good. Sweet f'in jeep OP.
Sent from AutoGuide.com App
kjeeper10 is offline
