rock krawler warranty questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 04-01-2014, 12:40 PM Thread Starter
So I bent my track bar and was wondering if anyone has done a warranty replacement that would be able to give me a heads up on the process? Thanks fellas.
So-Cal
Krew O.G.
RKDONKY (work in progress)
'11 JKU Rubicon, bright silver
jk_zero is offline
post #2 of 22 Old 04-01-2014, 12:46 PM
ALASHA's Avatar
Have you called them? I believe it is lifetime warranty on hard parts which includes the track bar
ALASHA is offline
post #3 of 22 Old 04-01-2014, 12:47 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Just call Rock Krawler and talk to Justin - 518-270-9822.
They'll get you fixed up.
Marcus
RiverCityOffroad is offline
post #4 of 22 Old 04-01-2014, 12:49 PM
TCdawg's Avatar
RK's track bar is seriously stout. let's hear the story about the bend?
Check your brackets too...if it was enough to bend the TB it was enough to tweak the hell out of the brackets
TC
TCdawg is offline
post #5 of 22 Old 04-01-2014, 12:51 PM
That too! I was thinking the same thing!
post #6 of 22 Old 04-01-2014, 12:58 PM
Wow, you world be the first to bend one of our track bars. If that is the case, we do warranty those bars for life. All we need is a digital picture of the bar showing installation and being bent. Then we will get you out another one.
RK
post #7 of 22 Old 04-05-2014, 02:02 PM Thread Starter
honestly not sure how it happened. i took it in for an alignment and they asked if i knew the track bar was bent. i had a buddy that had a new one that he let me have til i could get this one warrantied. i already replaced the track bar so pictures on the jeep would be difficult.
i replaced the axle side track bar bracket with an artec one already. ill take a look at the frame side bracket as well.
i can provide pictures from all angles of the bar off the jeep if that will work? if not i guess i will have to find time to install it and take pics.
thanks for the quick responses. RK customer service great as always.
So-Cal
Krew O.G.
jk_zero is offline
post #8 of 22 Old 04-06-2014, 09:50 AM
kjeeper10's Avatar
Your track bar differs from the one you put on ?
Sent from AutoGuide.com App
kjeeper10 is offline
post #9 of 22 Old 04-06-2014, 09:57 AM
Did they think it was bent because of the bend in it for diff clearance?
post #10 of 22 Old 04-06-2014, 11:18 AM
My TRE pulled out of my Rock Krawler track bar screwing up the threads. It was 12 months, three weeks old. Everybody I showed it to said the threads in the track bar didn't look like they were cut very deep. Rock krawler said they only guaranteed it for one year and would not help. I drilled it out, welded in new bungs.
dahreno is offline
post #11 of 22 Old 04-06-2014, 11:29 AM
H8MUD's Avatar
Why wasn't it covered under the Lifetime warranty if the threads are part of the track bar?
H8MUD is offline
post #12 of 22 Old 04-06-2014, 11:48 AM
kjeeper10's Avatar
I was thinking the same. Some people will think the stock drag link is bent. there's a tweak in it new.
post #13 of 22 Old 04-06-2014, 05:50 PM
The threads were part of the track bar. I was told it only had a one year warrantee. The shame is that it was only three weeks past that time and they wouldn't do anything.
dahreno is offline
post #14 of 22 Old 04-06-2014, 06:39 PM
kjeeper10's Avatar
Those jam nuts require a lot of torque. More then some can handle,
If the jam nut was not torqued properly securing the "heim joint". The sloppiness can ruin the threads.
post #15 of 22 Old 04-06-2014, 10:38 PM
The joint pulled out, passenger side wheel flopped to pass. side, almost went off a cliff.
dahreno is offline
post #16 of 22 Old 04-07-2014, 06:27 AM
Yep, i'll bet that's what it was, and slop WILL ruin threads to the point of pulling out. Probably the jam nut and or he had that joint really unscrewed and the other really screwed in. Either way he's just going to play-up on how traumatic it was, how evil RK is, even though it was likely his own fault [or whoever the installer was].
post #17 of 22 Old 04-07-2014, 06:45 AM
This. I used a big mother fucking pipe wrench to tighten the jam nut on my front track bar. Pretty sure it is torqued to around 200 ft lbs.
Terminator2 is offline
post #18 of 22 Old 04-07-2014, 11:10 AM
A JKO DICK
ASSFROW's Avatar
Yep, if it was fubar from the start and properly tightened, he would have found out while tightening from the bloody knuckles that smashed into something when it gave way while tightening. It was likely not tight or came loose. Locktite saves lives!.
ASSFROW is offline
post #19 of 22 Old 04-07-2014, 11:21 AM
If the bar is bent, we would certainly warranty it.
As far as threads are concerned, that is a customer intervention item and here is our stance regarding that.
"A note about jam nuts and the consumer's responsibility. The installer is the person or persons initially responsible for the proper setup of the suspension system and/or components and the initial tightening of the jam nuts. The consumer or vehicle owner is the person or persons responsible for maintaining the jam nuts tight. Jam nuts not only hold the orientation of a component or a joint, but their most important function is pre-loading the threads of the mating parts. Failure to not supply proper torque on jam nuts will result in the rapid deterioration of the threads in the control arm and will impose a "cause for concern" for the occupants of the vehicle. Failure to comply with the warnings headed in the directions regarding the amount of threads showing past the jam nut will also cause the same "cause for concern" for the occupants of the vehicle. All of the above items are the responsibility of the vehicle owner and or installer. If a threaded section of a component is bad it will show itself defective immediately. Threads that fail over time are due to improper maintenance of jam nuts and can be proven very easily. Thread sections not properly maintained or setup are not covered under warranty. This is the end user and installer's responsibility."
We typically hook the customer up with the part at cost, hopefully advise them as to what went wrong so it will never happen again and put them in a safe condition.
We apologize for anyone's inconvenience with this kind of issue. We are here to help...
RK
post #20 of 22 Old 04-07-2014, 02:24 PM Thread Starter
Thanks RK. I'll be in touch.
So-Cal
Krew O.G.
jk_zero is offline
post #21 of 22 Old 04-07-2014, 03:07 PM
If you bent it, a simple digital picture of it showing it was bent will do.
RK
post #22 of 22 Old 04-10-2014, 08:36 AM
JKO Dickhead
Asmmns's Avatar
odds .. this was the case and OP was misinformed by mechanic ? would love to see a picture !
__________________
CURE SMA !
Asmmns is offline
