Blew a shock this weekend - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 03-24-2014, 07:37 PM Thread Starter
Went for a trail run with a group of guys at Rpmfab this weekend. First time I've damage my jeep while wheeling. I guess this is what your get with no limiting straps.
Still a fun ride and I was still able to limp out after removing the shock on the trail
My jeep is the green one in the last pic
GreenThing13 is offline
post #2 of 20 Old 03-24-2014, 07:43 PM
Doing fast stuff or crawling? I've had limiting $40 SkyJacker shocks for years and haven't had trouble with them coming apart.
post #3 of 20 Old 03-24-2014, 07:43 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Don's looks so dinky compared to yours!
JKCTAZ is offline
post #4 of 20 Old 03-24-2014, 07:44 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
The trail they ran was not a fast stuff trail.
JKCTAZ is offline
post #5 of 20 Old 03-24-2014, 08:04 PM
Rubiconquered's Avatar
Psssh, maybe not for you Ya sissy! Lol
Sent from inside the Death Star
CRAWLIN PERFORMANCE 602-552-6793
Rubiconquered is offline
post #6 of 20 Old 03-24-2014, 09:04 PM Thread Starter
Ha ya it does, he's got all his parts on order, that thing is going to be sweet when all is said and done...stay tuned
Anyway the trail was more of the slow stuff, to be honest I was completely surprised when it broke as we weren't even on a rough part of the trail.
post #7 of 20 Old 03-25-2014, 05:46 AM
DaK
As my dad used to say, "Son, if you are going to do it, then do it right". And to me, that looks a might done right.
Never seen a shock come apart like that before. You may consider contacting the manufacturer. While they may not replace it one would think/hope they would be interested in seeing where the failure occurred with this unit.
We blew the seals on two Bilsteins running a washed out fire road at some pretty high speeds. After that we switched over to Kings and haven't had a problem since. Jeep is much more stable on off camber trails as well.
DaK is offline
post #8 of 20 Old 03-25-2014, 12:29 PM
BADGER's Avatar
How long did it take for the damping fluid taste to go away?
I'm sure there is a shaft joke in here somewhere too....
I'm curious to see what RK says about this one. Kinda weird it just completely came apart like that.
-Milton Friedman
BADGER is offline
post #9 of 20 Old 03-25-2014, 01:52 PM
Every day there is a new thread with one of their shocks leaking or in this case just falling apart.
Terminator2 is offline
post #10 of 20 Old 03-25-2014, 11:42 PM
RPMFAB's Avatar
Shock
In all fairness to RK, the lower shock mount was bent and took a hit from what I could tell. It looks like that put side pressure on the shock shaft as it traveled.
They are rebuilding it for only $40
We like their products and have had good luck with them. Our shop rig is getting the RK coil over system put on very soon.
RPMFAB
(480)329-2992
RPMFAB is offline
post #11 of 20 Old 03-26-2014, 03:24 AM
kjeeper10's Avatar
I lol'd
Sent from AutoGuide.com App
kjeeper10 is offline
post #12 of 20 Old 03-26-2014, 05:16 PM Thread Starter
[QUOTE=BADGER;2376145]How long did it take for the damping fluid taste to go away?
QUOTE]
I was expecting this on the first reply. Guess there are not as many out there with the same dirty minds as you and I.
post #13 of 20 Old 03-26-2014, 05:17 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Oh, a bunch of us thought it... Guaranteed!
JKCTAZ is offline
post #14 of 20 Old 03-27-2014, 06:34 AM
Once you bend the crap out of your lower shock mount like that, you are putting a ton of stress on the shaft and bearing assembly. Something will give at full extension. It is just like when the shock bodies lay up against the side of the frame or contract something. Running larger shafts makes them not want to bend as much, but if they see enough stress they will break. 3/4" Nitrotec Material can break pretty nasty too.
The real question is, what caused it to bend like that? Did he or she hit something or in a full droop condition was the shock body laying up against the side of the frame trying to bend it in half? Once this is determined a real corrective action can be taken to ensure it does not happen again.
Whomever is sending it back for a rebuild, please tell us their name so we can note this and be sure to replace the bottom cap with bearing assembly as well after seeing that much side load...
RK
post #15 of 20 Old 03-27-2014, 08:53 AM
Yeah that could be a big problem.
post #16 of 20 Old 03-27-2014, 09:49 AM
Jeepineer
JKred07's Avatar
Doesn't really matter who's shock it is, if you load it in any direction other than axially it will snap like a twig. This one looks like it bent at full droop, maybe due to that bend shock bracket...
I broke 3 rear shocks last year due to kissing rocks. It doesn't take much.
RK
To RK's point, besides checking the lower shock mount to see if the bearing housing contacted the mount, check and see if the body of the shock contacts the frame at full droop (should see marks on the shock body and on the frame). The lower shock mount may need to be outboarded some depending on total travel, axle arc, etc.
-Mike
JKred07 is offline
post #17 of 20 Old 03-27-2014, 10:50 AM
That is the biggest issue we have seen with JK front shocks is the side loading of them when they contact the frame up front. The second is guys using rear shock relocation brackets and the wrong application for shocks, wether they be our shocks or someone else's.
Long travel shocks up front do have the tendency to contact the frame under heavy articulation....
We will get this customer taken care of.... At second glance of the shock itself it does look like the top stud is bent too so there was a significant side load on the assembly for sure. What was the root cause we hope the customer finds out so it does not happen again.
RK
post #18 of 20 Old 03-27-2014, 11:24 AM
Yes and I said 45 minutes before you posted this that if the shock bracket was bent and putting the shock into a bind that could be a big issue. I did not know that shock and the bracket took a hit and were damaged as a result.
post #19 of 20 Old 03-27-2014, 11:31 AM Thread Starter
RK
Upon inspection of the shock housing there is a scuff in the metal at the same height of a sharp edge on the frame/shock mount.
I can see with the 3 link system up front the axle would shift over and cause the contact point under heavy articulation.
With the lower mount bent I will have to see about installing new mounts a little further out.
post #20 of 20 Old 03-27-2014, 11:37 AM
RPMFAB's Avatar
RK
Like I said, this was a bent tab and side force. The guys at RK are great to work with and we love their product. They have been very helpful in resolving the problem and RPMFAB will continue to support their line.
RPMFAB
(480)329-2992
RPMFAB is offline
