Rubicon Express 2.5" Budget boost w or w/o drive shafts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 03-21-2014, 09:15 AM Thread Starter
I am looking to purchase a 12+ 2dr in or around may. I am researching my future build now. I am looking at the RE 2.5" BB w/ twin tube and the mono (it will be one or the other. Also know the monos are tuned 5100s). Back to the point I will be running light with only possibly a stock VDP capped front and a smittybilt rear tire carrier running on 35s. I will also not be doing any crawling due to the lack of rocks in south louisiana. I will be playing in the mud and possibly a little sand. What I really need to know is should I replace front, rear or both drive shafts? I do not want to install the exhaust extensions b/c of the 3.6 tuned exhaust loop and just want to do it right the first time and possibly sell the stock DSs if they are undamaged. Any info will be a step in the right direction even recommendations on a different lift if there is better around the same price.
SLJK is offline
post #2 of 22 Old 03-21-2014, 09:22 AM
I would do a DS in front and leave the back alone. You could just use an exhaust spacer too. You will not get more than around $100 for the front and almost nobody wants the rear.
I wonder how they tune the 5100s- softer for these springs?
2014 JKUR White+white+white
Flyer is offline
post #3 of 22 Old 03-21-2014, 09:30 AM Thread Starter
Not a clue. Just relaying what I have read else where about tuned re branded 5100s.
I don't mind spending the money on DSs right out the gate so I am not playing the game of watching the boots. I would rather wait to hear a wine from the U joints on a strong DS and swap them out when needed. Especially for around $850 shipped for front and rear 1310s.
SLJK is offline
post #4 of 22 Old 03-21-2014, 10:59 AM
He will not need driveshafts at all. Just have the exhaust rerouted or install exhaust spacers. I have a 2013 2 door and 3000 miles so far at 6" of lift with 13" travel shocks (I rarely need all 13") and my driveshafts are still fine. I will replace them when they fail until then I will continue to run them. With a 2.5" lift unless you are running shocks intended for a 6-7" lift you will not need driveshafts for a long time unless you let the boots rot off of them.
Terminator2 is offline
post #5 of 22 Old 03-21-2014, 07:05 PM
aldo90731's Avatar
Correct. You will NOT need shafts for 2.5-inch lift.
I am on my third JK on a 2.5 lift; never had any shaft issues.
2013 Jeep Wrangler Rubicon
Warn 9.5ti winch
2.5-inch Teraflex lift
35-inch General Grabbers
2014 Jeep Wrangler Unlimited Sahara
Rubicon Wheels and Tires
aldo90731 is offline
post #6 of 22 Old 03-22-2014, 12:47 AM Thread Starter
Roger that. Thanks for the input. So basically just exhaust extensions?
SLJK is offline
post #7 of 22 Old 03-22-2014, 11:49 AM
Comfortably Numb
RubiCajun's Avatar
I've been running the RE 2-1/2" since I bought my jeep along with the stock tires. I've wheeled in Texas, Arkansas, Louisiana and Mississippi. There are quite a few places where there are rocks in La. Kisatchie National Forest, Sicily Island and near Saint Francisville. My opinion is leave the drive shafts alone and keep away from the quick sand, quick mud and "flotons".
RubiCajun is offline
post #8 of 22 Old 03-22-2014, 12:12 PM Thread Starter
Yeah after stating the lack of Louisiana rocks I saw the Catahoula Rec Park and started scratching. But back on point... So the stock shafts are gonna be cool as a cucumber. Just need the exhaust spacers and I will be golden. I will try to take your advice on staying out of the sticky but I grew up in the cane fields. Thanks for the advice.
Now I have an exhaust spacer question on what kind of loss in power do you get from doing that? With the hoop on the one side to give the exhaust its equal length adding the spacers does it mess with the torque? Just wondering. I will be doing a traildash, intake, exhaust and a lil n2o to recoup any loss in power.(I already have the nitrous kit sitting at the house so why not)
SLJK is offline
post #9 of 22 Old 03-22-2014, 12:20 PM
No noticable power loss with my exhaust spacers but I do plan on rerouting the whole exhaust system putting a 5-6" round magnaflow muffler on where the factory resonator is and having everything welded up tight. I have a couple tiny exhaust leaks.
post #10 of 22 Old 03-22-2014, 04:38 PM Thread Starter
Ok sounds like a plan. Guess I will have an extra $850 to put else where. I guess the RE 2.5 w monos will be the lift of choice then. I appreciate all the help.
SLJK is offline
post #11 of 22 Old 03-22-2014, 04:40 PM
RedRubiconLJ's Avatar
What about track bars F&R, with or without brackets, if they are needed?
RedRubiconLJ is offline
post #12 of 22 Old 03-22-2014, 05:16 PM Thread Starter
I was just looking at track bars and wondering the same thing or are the brackets good enough?
SLJK is offline
post #13 of 22 Old 03-22-2014, 08:00 PM
I would do adjustable front and rear track bars.
post #14 of 22 Old 03-23-2014, 07:25 AM
tapcola's Avatar
FWIW , I have the RE 3.5 supper flex , I run light no armor yet and it is pretty stiff , I would look around , say EVO or RK for a better ride ,just my 2 cents !
tapcola is offline
post #15 of 22 Old 03-23-2014, 08:37 AM Thread Starter
Thanks for the info. Anyone know if the Superlift springs worth a shit?
SLJK is offline
post #16 of 22 Old 03-23-2014, 02:28 PM
What shocks are you running? That has more to do with ride IMO than the springs. Stiff shocks will make your Jeep ride like crap.
Ive had 3 RE sf lifts and they all rode Great. I was using rancho adj 9000shocks.
post #17 of 22 Old 03-23-2014, 02:45 PM
wicked1921's Avatar
Nitrous? Really? Anyone done that before? Im only asking because i have an old n.o.s. kit sittin in my garage. Guess it would be good for wheel spin in mud.
wicked1921 is offline
post #18 of 22 Old 03-23-2014, 03:38 PM
kjeeper10's Avatar
Agree, for coils. MC, Synergy or RK's new triple rates. Shocks ... Check out the Rebate going on Rancho shocks.
The 7000's are compatible to the Billy's but not as harsh, 9000's are adjustable. Tune to your liking.
I'm seeing less than $250 for 4 9000's after the rebate.
Wait .... Nitrous what ? A Sneaky Pete kit in a jeep rofl
Sent from AutoGuide.com App
kjeeper10 is offline
post #19 of 22 Old 03-23-2014, 03:46 PM
kjeeper10's Avatar
Not needed at 2.5" of "actual lift" most your 2.5" coils will yield more height. For Track bars -
A front is nice to have adding some rigidity to the steering.
For the rear, you really don't need a adjustable track bar. A axle bracket is enough to reposition the axle and raise roll center. Some kits run TB drop brackets which I don't recommend.
post #20 of 22 Old 03-23-2014, 04:29 PM Thread Starter
ok so a front track bar would be good and the bracket is cool for the rear.... As for nitrous I have an old kit sitting in the shed that came off my old honda and chevy pick up. So it has seen 2 vehicles on opposite ends of the spectrum. My truck was an 02 silverado 4x4 with a 4.8 cammed w/ nitrous and it was a fun run. Just figured why not run it on a jeep as well seeing as no one else is.
SLJK is offline
post #21 of 22 Old 03-23-2014, 04:45 PM
kjeeper10's Avatar
Nothing to add on that. I'm just picturing a hand slip and somebody rockets themselves off a cliff lol
Jk .... Yes. Front track bar and a rear axle bracket like this one (Teraflex)
Also included A pic of Synergys (not mine)
Size:  700.1 KBName:  ImageUploadedByAutoGuide1395614680.126525.jpg
post #22 of 22 Old 03-23-2014, 05:45 PM Thread Starter
roger that. Looks like the rear track brackets pictured are a little beefier than the normal in the other kits i have seen that merely bolt onto the existing bracket causing that much more leverage on them.
SLJK is offline
