Still bad shimmy but not deathwobble - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 03-19-2014, 11:04 AM Thread Starter
Ok so after installing a lift I had death wobble went to a shop an had new steering stabilizer done new castor bolts and 2 alignments I just installed new teraflex monster track bar and now it is just a shimmy when I go off of a drop in the road what could it be? I have small clunk in drag link when I have someone turn the wheel in park but it doesn't seem real loose! Anyone have any suggestions
Alexf7019 is offline
post #2 of 16 Old 03-19-2014, 11:13 AM
kbiv's Avatar
My drag link at the knuckle side has very small play in the ball joint, and I can feel if I hold it while someone moves the steering wheel. This causes mild death wobble when I hit a pothole or bump in the road that goes away in a couple of seconds. I have a replacement draglink on the way. Even a small amount of play can be amplified in the steering...
kbiv is offline
post #3 of 16 Old 03-19-2014, 12:00 PM Thread Starter
Ok thanks I guess I'll be ordering the synergy draglink
post #4 of 16 Old 03-19-2014, 12:43 PM
this:
https://www.jkowners.com/forum/showthread.php?t=30723
post #5 of 16 Old 03-19-2014, 06:50 PM
Mine was related to balljoints , Don't replace yours with factory crap-o , find something better. Watch the vids. that USMC suggests they are really must see. You will probably never have to ask about death wobble again......regards k.
slick pickel is offline
post #6 of 16 Old 03-20-2014, 05:17 PM Thread Starter
Well the bushing on my balljoint I am able to rotate with my fingers is that normal or no?
post #7 of 16 Old 03-20-2014, 05:25 PM
planman's Avatar
They say, you can lead a horse to water, but you can't...
...make them read the thread and watch the videos that answer all their questions...
planman is offline
post #8 of 16 Old 03-21-2014, 06:50 AM Thread Starter
I have watched both of your videos Planman and I've done the inspections the only thing I have a clunk in is my draglink but it doesn't seem loose on either end maybe that's my problem I don't know
post #9 of 16 Old 03-21-2014, 07:12 AM
Replace the drag link.
Terminator2 is offline
post #10 of 16 Old 03-21-2014, 07:28 AM
planman's Avatar
A clunk means that the ball of the end is loose in the cradle. This isn't a drawing specifically of a JK end, but the design is similar. As you look at it, picture in your mind what would need to be loose or worn for the ball of the end to clunk inside the end.
planman is offline
post #11 of 16 Old 03-23-2014, 10:20 AM Thread Starter
Could a bad draglink be causing bad shimmies or death wobble? I think I may go with the synergy draglink any takes on it?
post #12 of 16 Old 03-23-2014, 10:49 AM
kjeeper10's Avatar
Same ... A friend was experiencing shimmy. Determined to be a bad TRE at the pitman arm. We are replacing the drag link with a Synergy one.
Sent from AutoGuide.com App
kjeeper10 is offline
post #13 of 16 Old 03-23-2014, 11:51 AM
Yes and yes.
post #14 of 16 Old 03-23-2014, 07:35 PM Thread Starter
Ok awesome thanks guys the synergy will fit my jeep with only 2.5 lift right?
post #15 of 16 Old 03-23-2014, 07:58 PM
kjeeper10's Avatar
Yes, can be run stock or flipped.
post #16 of 16 Old 03-23-2014, 09:27 PM Thread Starter
Ok thanks!
