Rear Axle Flange - JKowners.com : Jeep Wrangler JK Forum
post #1 of 27 Old 03-17-2014, 10:12 PM Thread Starter
azrockzuk's Avatar
Rear Axle Flange
Bent rear passenger axle flange on my 09 Rubicon!!!
Looking for good deals and options of who to go with for NEW after market rear inner AXLE's???
I am looking to purchase rear axle with the ABS Tone Ring and ect. (all in one package) so I can keep the stock rears as spares…
Thanks for the input!!!!
Chad
azrockzuk is offline
post #2 of 27 Old 03-17-2014, 10:28 PM
What's your location? I have a set in SoCal
Doormandan is offline
post #3 of 27 Old 03-17-2014, 10:34 PM Thread Starter
azrockzuk's Avatar
Scottsdale AZ
What do you have? After market??
Chad
post #4 of 27 Old 03-18-2014, 12:37 AM
I just ordered a set of G2 Gold series for the back end of my jeep from 4wheel parts. I'm not a real fan of 4wheel part but they had a jeep and truck fest going on locally and I was able to get a the complete set with studs and bearings for $509 with a 25 year warranty no questions asked.
Speedsparky is offline
post #5 of 27 Old 03-18-2014, 03:53 AM
kjeeper10's Avatar
You can source Tens for $400-$425 ready to bolt in. I don't think there's many options for warrantied flanges. TEN is one iirc.
Sent from AutoGuide.com App
kjeeper10 is offline
post #6 of 27 Old 03-18-2014, 06:22 AM
I just bought the Tens, they only come with the bearings and seals and studs. You will have to buy the tone ring and retainers elsewhere.
post #7 of 27 Old 03-18-2014, 06:28 AM
You should have gotten tone rings, we bought two sets of Ten's at the same time. One was missing tones, one was missing studs and something else. You paid for tones, hit up whoever sold them to you and get Ten Factory to send them.
post #8 of 27 Old 03-18-2014, 07:01 AM
kjeeper10's Avatar
Northridge was sourcing the tone rings/bearings and pressing them in. $50 I think.
post #9 of 27 Old 03-18-2014, 07:53 AM
I guess I need to look in the box then.
post #10 of 27 Old 03-18-2014, 08:05 AM Thread Starter
azrockzuk's Avatar
Can you get the G2 gold with 32sp. for a stock rubicon???
post #11 of 27 Old 03-18-2014, 10:28 AM
I stand corrected, the tone rings come with the Tens.
post #12 of 27 Old 03-18-2014, 09:14 PM
Yep.......well thats what their representative told me. I think that it's a new part. The part number on my invoice is 196-2052-032 if your interested.
post #13 of 27 Old 03-18-2014, 11:50 PM Thread Starter
azrockzuk's Avatar
You have and received your new axles yet? When did you buy them?
Do you have a phone# for the rep.?
I would like to get a set today if they make them!!!!
Thanks for your help!!!!
Chad
Chad
post #14 of 27 Old 03-18-2014, 11:52 PM Thread Starter
azrockzuk's Avatar
I bent my stock driver side Rear flange.. I am running 37 inch MTR's with big offset on Allied Beadlocks. So lots of weight on the stock axles
Chad
post #15 of 27 Old 03-19-2014, 06:25 PM Thread Starter
azrockzuk's Avatar
Yes, you are correct!! They make them now!!!
Chad
post #16 of 27 Old 03-19-2014, 06:30 PM Thread Starter
azrockzuk's Avatar
I did go with 10 factory axles as they have the best warranty and purchased them at Northridge in WA. Best customer service ever!!!! They also press bearings, ABS, and ect. then ship them !!!! So plug and Play!!
Thanks again for all the info and help guys….
Chad
post #17 of 27 Old 03-19-2014, 08:01 PM
TCdawg's Avatar
You'll eventually bend the flange on the Chromo Ten's too...back space and big tires will do it. At least you've got the warranty.
TC
TCdawg is offline
post #18 of 27 Old 03-19-2014, 08:52 PM
I can see that happening in my future with 3.75" BS Walkers and 1.375" pattern adapters....2-3/8" backspacing ftw
post #19 of 27 Old 03-19-2014, 08:53 PM Thread Starter
azrockzuk's Avatar
Yea I should have got 2 pair!!!!
I see a dana 60 in the future….
Chad
post #20 of 27 Old 03-20-2014, 07:29 AM
TCdawg's Avatar
Full Float...
TC
TCdawg is offline
post #21 of 27 Old 03-20-2014, 08:00 AM
Did you get the axle shaft seal retainers as well?
post #22 of 27 Old 03-20-2014, 10:02 AM
Here's another vote for Northridge and Tens. Only company that warranties the flange. $450 ready to slide in. Tone rings, bearings and bearing plate with studs. You just need to get new bearing plate torque nuts from the dealer
bjoneill is offline
post #23 of 27 Old 03-20-2014, 10:31 AM Thread Starter
azrockzuk's Avatar
Yes I did!!! I wanted it Plug and Play..
They sent them ready to go side in everything all ready pressed on for $450
Now I can keep my old axles as spares…
Chad
post #24 of 27 Old 03-20-2014, 10:32 AM Thread Starter
azrockzuk's Avatar
It does not come with the Bearing Plate??
I think I could use the old Nuts off the old bolts??? Yes
Chad
post #25 of 27 Old 03-20-2014, 10:53 AM
None, in my research, come withe the bearing plate and tone ring. Northridge presses them on for you. The G2 Golds also need the bearing, plate and tone ring pressed on, for an additional charge. At least the 4 wheel parts here it was that way.
bjoneill is offline
