Antifreeze leak at thermostat housing - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-15-2014, 06:14 PM Thread Starter
4wheels4life's Avatar
Have looked and read some posts on this but have not really found out what to do. I have a leak at what I will say is the back bolt that holds the thermostat housing on. Any way it looks as though the fluid is leaking there. I have replaced the hose clamp with a screw clamp design and still have the leak. Does anybody know is that back bolt hole blind or open into the water cavity and last what has been done to fix the leak?
2007 JKU X, 6.0 ls and 6L80e with a diy kit from RpmExtreme, 4.10, 4" ProComp Stage 1 lift, AEV drop brackets, 315/70R17 Milestar Patagonia MT , Vision Nemesis 111, 17X9 wheels
4wheels4life is offline
post #2 of 3 Old 03-15-2014, 07:38 PM
txjeeplover's Avatar
Have you considered just replacing the thermostat and thermostat gasket? From what I recall, there is no housing gasket, just the rubber seal around the thermostat. If you still have the factory thermostat and gasket, I'm sure that the gasket has deformed and its ability to seal has been diminished.
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
35x13.50R15 Toyo Open Country MT
A bunch of other stuff done and yet to do
txjeeplover is offline
post #3 of 3 Old 03-16-2014, 01:41 PM
Stopher's Avatar
If you replace the thermostat make sure they sell you the right one. My "new" one leaked until I removed it again to replace and realized it was slightly different than the correct one.
08 "X", RC BB, 33" Duratracs, Coast 1310 front, Hellfires, Woods evap relo.
Stopher is offline
