Page 1 of 2 | 1 | 2 |
DIY Security Deck
List of materials:
$27 - 4x8 sheet of 1/2" MDF (or whatever material you want to use)
$26 - 24" Airline Track Style Logistic Track - Black (2)
$20 - L-Track Rings
$20 - HD Gate Latches (2)
$20 - Misc Hardware
$30 - Simple backpacks. I got 3 of these in black
$20 - Cargo Utility Mat
$6 - Weather Stripping (for the back edge)
$4 - 1/4" Turn Buckles
I use 1/2 MDF for 2 reasons. I had a sheet in the basement and the track was 1/2 high. I wanted to track to be recessed on the deck. I used 1/4-20x3/4" flat phillips head screws and t-nuts to secure the tracks.
Overall deck measurement is 43" wide by 34" deep.
Hopefully you can see how it's made from the pictures. I just kind of winged the design it as I went. I probably put the most thought into how I was going to secure it to make sure it couldn't be lift up. I decided on gate latches in the back because it makes for quick removal and it doesn't leave behind any hardware bolts to the jeep. In the front, I used a 1/4-20 turnbuckle and removed the eye bolt and put in a 2" all thread 1/4-20 bolt. It was kind of tight for me to reach back there to turn them tight, but it works.
You can see that I relocated the factory sub woofer. I traded a forum member (Levi_Cope) for his non-sub woofer panels because he was looking for a factory sub enclosure. Worked out great or both of us.
Overall about $175 to build it. I had a lot of the stuff laying around so I don't have that much in it. Sure as hell beats the $645+ one that one of the forum vendors sells. The entire unit weighs about as much as the rear set. I can remove the deck in less than 5 minutes if I want to put the rear seat back in.
, Granite,
Sponsored Links | |||
Advertisement |
, Granite,
, Granite,
Advertisement |
That turned out realllly nice!
Dumb audio question, how is the sub firing sitting flat on the floor without any reliefs on any side?
Originally Posted by braindead0
View Post
Originally Posted by JKCTAZ
View Post
There is about 3/4" of relief for the sub. I probably should have set it deeper. I packed the sub box with poly-fill.
, Granite,
Why so short though?
Originally Posted by BigMike
View Post
Thanks!
Also, I noticed that notch for the tab, that sub requires a completely sealed airspace. Otherwise, it will sound muddy and get weird resonant frequencies. Try to seal that off with some silicone or hot glue.
View Post
Short in depth or height?
Depth because I wanted to be able to recline the seats fully. Also, there is only so far you can reach back to get stuff out.
Height because all of the stuff that I'll put in there to lock away will be in backpacks. I had a Tuffy security box in the back of my '09 2 door and took up the entire rear. I want my dogs to be able right back there too.
This is what I was going after. http://orv-innovations.com/
, Granite,
View Post
I'm talking about reliefs in the area around the baffle to let the sound waves escape, see my edit. If that box sits flat on the floor, you aren't going to get anything out of that sub.
, Granite,
View Post
View Post
Very nice.
a.k.a. Christian - 2011 Black Jeep Wrangler JKU Rubicon
37" MTRK, RK 3.5 X-Factor (3-Link Rear) and other stuff..
Owner/Manager -
and other Web Properties
I think that I'm going to disable the electric lock for the tailgate or put a toggle switch on it. It would be pretty easy for someone to just hit the unlock button and open the tailgate.
, Granite,
View Post
Originally Posted by espi
View Post
I thought once you lock the jeep with the keyfob the door switches are disabled after about 16 seconds.
, Granite,
Yep, looks like you're right
The Vehicle Security Alarm is designed to protect your
vehicle; however, you can create conditions where the
Vehicle Security Alarm will arm unexpectedly. If you remain in the vehicle and lock the doors with the RKE
transmitter, once the Vehicle Security Alarm is armed
(after 16 seconds), when you pull the door handle to exit,
the alarm will sound. If this occurs, press the UNLOCK
button on the RKE transmitter to disarm the Vehicle
Security Alarm. You may also accidentally disarm the
Vehicle Security Alarm by unlocking the driver’s door
with the key and then locking it. The door will be locked
but the Vehicle Security Alarm will not arm.
NOTE:
• Unlocking the doors with the manual door lock plungers
or the driver’s door lock cylinder will not disarm
the Vehicle Security Alarm.
• When the Vehicle Security Alarm is armed, the interior
power door lock switches will not unlock the doors.
NOTE:
, Granite,
Ive been looking at doing the same thing ever since i saw the stealth shelf.
have you figured out any type of tote or bag that will fit under this?
Originally Posted by oscar the grouch
View Post
, Granite,
View Post
i want to find those oro bags. curious as to who their supplier is .
, Granite,
are you going up to helen this weekend for the jeep fest?
I made a little deck to cover the rear footwells so my dogs would have more room have you thought about extending this to hit the back of the seats at all?
View Post
, Granite,
there shouldnt be much of a crowd anyway. its first year. My site is handling the trail rides and were not expecting more than 200
View Post
, Granite,
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
