spyntec hub conversion questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 03-09-2014, 10:25 AM Thread Starter
http://spyntec.com/jeep_wrangler_jk_spyntec_overview/ (used)
so i can get a deal on a complete set up, front hub conversion and and f/r up graded shafts
yea i know the bolt pattern changes to 5x5.5 but the question is how do they hold up i would really like to have hubs just to have the 2wd also i would be putting in gears and lunch box lockers front and rear,
Adrenaline Fab
toolegit86 is offline
post #2 of 8 Old 03-09-2014, 02:36 PM
halo216's Avatar
Looks like you own an automotive shop? You can probably swap in a new axle for less.
halo216 is offline
post #3 of 8 Old 03-09-2014, 08:10 PM Thread Starter
yea i can get a 44 for around 1300 but i can get the shafts and hubs everything for 700$ also i only plan to run 35s on my jk for now
Adrenaline Fab
post #4 of 8 Old 03-10-2014, 01:32 AM
halo216's Avatar
Oh I thought kit was 1400 thats not bad then.
halo216 is offline
post #5 of 8 Old 03-10-2014, 02:04 PM Thread Starter
yea i was thinking about trying it. i plan to beat my jk just keep it simple and see what it does.
Adrenaline Fab
post #6 of 8 Old 03-10-2014, 08:11 PM
SoK66's Avatar
I've had them on my '09 JKUR since '10. They work great, are very robust. They are sensitive to setup, tolerating no bearing end play whatsoever. I chewed up a set of spindles learning this the hard way. The handling difference between locked in and unlocked is a revelation, and there is a mileage gain as well. With 37" MTR/Ks on TR beadlocks I get about 16 around town, 18 on the highway. They've endured many trips to Moab, Mt Blanca a few times, Chinaman's Gulch etc. and total carnage has been one broken lock ring. I may upgrade the hubs to Yukons some day but for now I run them with Synergy's RCV 911 inner gears and they seem to be tough as nails. Spyntecs are essentially CJ 30 spline Warn Premium hubs on proprietary hubs & spindles. Seals aren't off the shelf automotive stuff, so good to lay in a few sets for servicing.
So, are they worth the upgrade? Yes, IF you do so at the beginning of your build. At the time I built the rig angle corrected housings weren't yet available and I had a bad front DL vibe issue. So, I ended up getting a second set of wheels for the bolt pattern change. I also had to drop down a size in front inner shafts, but got chromolys and CTM U-joints, which have gone everywhere without complaint. I later found out RCV will make a set for Spyntecs, so if I break these that's how I'll go.
All that said, as I've mentioned in other threads had I to do over again I wouldn't put a penny into the stock front JK axle housing. I'd just get a corrected Pro Rock or Tera 44 and be done with it.
SoK66 is offline
post #7 of 8 Old 03-11-2014, 05:02 PM Thread Starter
thanks for the info.. i might end up going tons.
Adrenaline Fab
post #8 of 8 Old 03-11-2014, 10:39 PM
SoK66's Avatar
Better move if you can pull it off. The axle builder companies don't make it a cheap swap-out, and the cheap ways to do the swap-out don't make it easy.
SoK66 is offline
