Rear sway bar issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 03-05-2014, 12:05 PM Thread Starter
So when I got my 2013 it had a 1 3/4" daystar spacer lift already on it. I took it off when I put on my TF lift. I thought it was just cool spacers but it also has a rear swaybar drop bracket. Didn't find out till after everything was installed and noticed the end links at rubbing the upper control arm mount. Is thay normal or what should I do? I don't know what it's supposed to look like factory.
Do I just remove the spacer and bolt the swaybar back up to the frame?
zpayne08 is offline
post #2 of 18 Old 03-05-2014, 01:29 PM
Pictures, or a more thorough description would help a lot. Did the lift kit come with rear end links? Are they adjustable? Did the shop put them in? If so, pull the drop brackets and adjust them to the proper length. At ride height, are the arms on the bar parallel with the ground, pointed up or pointed down?
Wangmuf is offline
post #3 of 18 Old 03-05-2014, 02:36 PM Thread Starter
The drop brackets were on the previous spacer lift the dealer put on. The new cool lift came with longer end links so that it wouldn't need a spacer. I installed the lift and they installed the 8 control arms and did alignment. Now I noticed that one, maybe both end links are bent
zpayne08 is offline
post #4 of 18 Old 03-05-2014, 02:39 PM Thread Starter
The spacer lift is uninstalled and out of the question which is why I removed the swaybar drop spacer. I didn't even know it had one till I saw my buds didn't have one and I got online and looked at the spacer lifts kit specs.
I was hoping that putting it back to original to original location would help but doesn't look like it's gonna matter (I had to order factory bolts from mopar that will be here tomorrow)
zpayne08 is offline
post #5 of 18 Old 03-05-2014, 02:43 PM
I'm gonna guess it's a byproduct of your trackbar not being adjusted properly, putting sideways stress on the end links.
Wangmuf is offline
post #6 of 18 Old 03-05-2014, 03:06 PM Thread Starter
The track bar should be bc it's evenly spaced on both sides (I have front and rear adjustable teraflex bars)
zpayne08 is offline
post #7 of 18 Old 03-05-2014, 04:42 PM
https://www.jkowners.com/forum/showthread.php?t=164625
That's not you?
If the axle's not centered under the vehicle, there's sideways force against everything connecting the body to the axle. If the difference between driver side tires showing vs. passenger side showing is inches, as you say, that's plenty to bend an end link, and maybe put one of them into a upper control arm mount on one side under compression.
Wangmuf is offline
post #8 of 18 Old 03-05-2014, 04:55 PM Thread Starter
I centered them both today. It probably happened while it was off center
zpayne08 is offline
post #9 of 18 Old 03-06-2014, 10:32 AM Thread Starter
Here's the pics
Passenger side
Drivers side
zpayne08 is offline
post #10 of 18 Old 03-06-2014, 08:02 PM Thread Starter
I called TF today and emailed them pics. They said the shop lengthened the control arms a little to far. Called the shop and they went by the instructions which show measurements for 3" lift. The front is almost touching the springs too. Even though they went but instructions surely they woulda noticed something was wrong when the end links were hitting the upper control arm bracket. They're gonna fix it for me Monday though
Soo thanks to me teraflex is working on doing measurements for all their different lifts besides 3" and 4" to add to the control arm install instructions
zpayne08 is offline
post #11 of 18 Old 04-08-2014, 10:48 AM Thread Starter
UPDATE
when i installed everything originally with the 8 teraflex arms them being adj too far out caused the rear sway bar lings to get bent. the shop shortened the arms as much as possible and this fixed it but they were still pretty close and i never got around to putting the replacement links on until about 30 min ago after i put the factory lower control arms back on. come the find out the end links that came with the kit were 1.5" shorter compared to the replacement end links! that was most of the problem all along. the swaybar is at a better angle now than it was before but the links are almost touching the upper CA brackets like they were with the TF lower CAs installed.
so heres the question. if i put the TF LCAs back on in the back will it tilt the axle enough to move the end link off of the bracket or not?
zpayne08 is offline
post #12 of 18 Old 04-08-2014, 11:40 AM
PIG
PIG's Avatar
Depends on the over length....
PIG is offline
post #13 of 18 Old 04-08-2014, 12:05 PM Thread Starter
They're as short as you can make the teraflex arms
zpayne08 is offline
post #14 of 18 Old 04-08-2014, 12:29 PM Thread Starter
Stock length is 19-3/4". The TF are adjusted to 20"
zpayne08 is offline
post #15 of 18 Old 04-08-2014, 04:00 PM
PIG
PIG's Avatar
Something is not adding up here... Are you measuring center of bolt hole to center of bolt hole?
PIG is offline
post #16 of 18 Old 04-08-2014, 05:13 PM Thread Starter
Yes I am. What's not adding up?
zpayne08 is offline
post #17 of 18 Old 04-08-2014, 05:59 PM
PIG
PIG's Avatar
The fact that that the lower arm is .25" longer than stock on a 1.75" spacer lift and the RUCA bracket has interference issues.
Check these links below for CA length suggestions for varying ride heights.
JK Rear Lower Control Arms
JK Rear Upper Control Arms
PIG is offline
post #18 of 18 Old 04-08-2014, 07:07 PM Thread Starter
I have a 2.5" teraflex lift. The spacer lift was on when I got the jeep and I removed it
zpayne08 is offline
