tires stick out further on one side... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 03-04-2014, 01:46 PM Thread Starter
I just finished lifting my 2013 with a 2.5" teraflex coil lift, both of their adjustable monster track bars, all 8 of the adjustable flex arms, and bilstein shocks. had a shop do the arms and the alignment and install the arms. I noticed when I just got it back the the drivers side tires stick out a couple inches further than the passenger. what will I need to do to fix this and will it affect the alignment any? thanks
zpayne08 is offline
post #2 of 7 Old 03-04-2014, 01:48 PM
Blackr6's Avatar
Lengthen trac bar
Blackr6 is offline
post #3 of 7 Old 03-04-2014, 01:49 PM
honeybadger08's Avatar
The track bar should have fixed that. Did u adjust the track bar right?
honeybadger08 is offline
post #4 of 7 Old 03-04-2014, 01:57 PM
10jk's Avatar
Originally Posted by Blackr6 View Post
Lengthen trac bar
And shorten rear track bar.
Both of these actions will make the front and rear axle go to the passenger side in relation to the body position.
Front goes from Drivers frame to pass axle
Rear goes from drivers axle to passenger frame
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #5 of 7 Old 03-04-2014, 02:27 PM Thread Starter
I got it the best I could but told the shop to do it once they got the arms on but I guess the forgot. Will it mess up the alignment? If not I'll try to so it myself. Also, it needs to be on the ground, correct?
zpayne08 is offline
post #6 of 7 Old 03-04-2014, 03:30 PM
Blackr6's Avatar
Yup. Just let it settle on the ground then extend your TBs to line up with the holes
Blackr6 is offline
post #7 of 7 Old 03-04-2014, 05:04 PM Thread Starter
The trackbar is adjustable while mounted
zpayne08 is offline
