Hard Top question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-28-2014, 08:43 AM Thread Starter
Question Hard Top question
Question about a 2008 JKU hard top. Will a hard top off 2008 JKU fit a 2013 JKUR? Thanks in advance for your feed back.
Reason I ask, I had a 2008 freedom top given to me. It's in great shape. The color is gray, if it will fit I'm going to have it painted to color match the Jeep.
Nardo is offline
post #2 of 3 Old 03-01-2014, 12:30 AM
UnlimiDozer's Avatar
Yes. (Unless they changed something after 2012, but I'm not aware of it if they did.) I have a 2008 on my 2012.
Unless your '13 came with a hard top, you'll probably have to spend the 156.95 on the wiring harness if you want the washer/wiper/defroster to work. Probably also have to have the dealer flash it so the wiper works right instead of the wonky partial sweeps mine does. :lol
If I recall the date correctly, 2010 and later tops have a wider back glass, and the center latch on the freedom panels catches a loop on the windshield, whereas on the older tops, the center latch just ties the two panels together.
Sounds like the price was right on your top, so even if you had to spend $300 to $600 to get everything in the condition you want, you'd still be way ahead.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #3 of 3 Old 03-01-2014, 12:31 AM
Will Scarlet's Avatar
This question have been asked many times here. Try searching for your question and you'll find the answer.
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, Fox 2.0 reservoir shocks, and more to come...
Will Scarlet is offline
