Willy's Wheeler with Rough Country Lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 02-26-2014, 12:52 PM Thread Starter
I missed my 2007 Unlimited Wrangler so I had to order a 2014 Willy's Wheeler. I again went with the Rough Country 6" X Series Suspension Lift. No doubt you get a lot of bang for the buck. As a novice mechanic, I was able to install the lift, steering stabilizer, and driveshafts in a weekend. Also, added the Moto Metal M0962 (20x12) and 38x15.5x20 Toyo Open Country MT's. It is a tight fit but no rubbing. After selling the stock wheels/tires and other extra parts, I am sitting at a net of just over $3k for the changes. Money well spent...
BAJK_ is offline
post #2 of 9 Old 02-26-2014, 12:54 PM
Why did you put this in land use?
post #3 of 9 Old 02-26-2014, 01:09 PM
StubEXrube's Avatar
Definitely.
Moved it.
StubEXrube is offline
post #4 of 9 Old 02-26-2014, 01:16 PM
Rolltidejk's Avatar
Be ready to spend more on an axle housing when you bend the C's as well as ball joints, probably axle shafts, and the RC joints and bushings will not hold up long. But if your cruising the mall and careful around speed bumps you might be OK.
Rolltidejk is offline
post #5 of 9 Old 02-26-2014, 01:17 PM
Cavallini03's Avatar
Definitely.
Moved it.
Why'd you move it to CJ and YJ? The willys wheeler is a sticker package on the 2014 JK's
Cavallini03 is offline
post #6 of 9 Old 02-26-2014, 02:15 PM
Dammit don't confuse him. He just got his little whore jeep back from being finger banged at the dealer for far too long.
post #7 of 9 Old 02-26-2014, 02:23 PM
Sorry Stub!
post #8 of 9 Old 02-26-2014, 02:44 PM
StubEXrube's Avatar
lmfao. Indeed!
Just moved it. Didn't read thru the post to see that it was a JK "upgrade". You kids and your fancy option packages.
post #9 of 9 Old 02-26-2014, 03:23 PM
Jaybee1669's Avatar
It least it wasn't the dragon sticker package.
Jaybee1669 is offline
