How to tell what gears I have? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 02-25-2014, 06:08 PM Thread Starter
Short of taking apart the diff and looking, whats the most accurate way to know what gears I have in my JKU? Im about to order some 35s and I want to know if I can slide by without gears for a while or if its going to be too much.
AXIS is offline
post #2 of 8 Old 02-25-2014, 06:15 PM
ronjenx's Avatar
Jack a front tire off the ground.
Put a chalk mark on the tire and the drive shaft.
Rotate the tire by hand 2 complete revolutions while counting the drive shaft turns. The number will be your gear ratio.
A little less than 3 and 1/4 turns will be 3.21 gears.
About 3 and 3/4 turns will be 3.73 gears.
A little over 4 turns will be 4.10 gears.
ronjenx is offline
post #3 of 8 Old 02-25-2014, 06:27 PM
JKO Dickhead
Asmmns's Avatar
The most accurate way is to submit you VIN to Chrysler electronically and get your build sheet. I got mine in a few hours. I think the link is on here somewhere if you search.
Of course this will be the most accurate if you are talking about stock and they haven't been replaced.
__________________
CURE SMA !
Asmmns is offline
post #4 of 8 Old 02-25-2014, 06:28 PM
JKO Dickhead
Asmmns's Avatar
here ya go :
https://www.jkowners.com/forum/showthread.php?t=48051
__________________
CURE SMA !
Asmmns is offline
post #5 of 8 Old 02-25-2014, 06:30 PM
ronjenx's Avatar
Original owners have had the build sheet be in error on their stock JKs, too.
You just can't beat going out to the Jeep and actually checking it.
ronjenx is offline
post #6 of 8 Old 02-25-2014, 07:09 PM
I just searched on google and came to a Chrysler website and typed in my vin and pulled up my sheet on my phone right there. I will try and find the link.
2007 JKU auto 2" budget boost (temporary) 15x8.5 MB TKO wrapped in 35 KM2
SEMPER FI
slomo is offline
post #7 of 8 Old 02-25-2014, 08:34 PM
Here is the url. Add your vin to the end, paste it to your browser and your build sheet will come up....should have the axle ratio listed on there...
http://www.jeep.com/webselfservice/B...etServlet?vin=
NJSP117 is offline
post #8 of 8 Old 02-25-2014, 09:22 PM Thread Starter
Jeeps site shows that it has 4.10s which is good news but I will definitely check once I get a chance to jack it up. Thanks guys
AXIS is offline
