Gear oil change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 02-24-2014, 07:38 PM Thread Starter
Gear oil change
Changed the gear oil today and replenished with Mobil 1 75w90. Made it a point before draining to position the jeep so the would run out downhill. And to fill positioned the Jeep so I could maximize what I could put back in. So I have read the rear 2.375 or whatever quarts and 1.35 quarts in the front. Well my issue is I am about 12oz short in both front and rear. For the back I jacked up the rear end as high as I could even added a 6x6 for extra height. Is it common to not be able to get the full amount in? Is it imperative that I tr to get the last little bit in? I got 2 quarts in Rear and 1 in the front. What do the experts advise ?
da20captain is offline
post #2 of 5 Old 02-24-2014, 07:45 PM
jason mac's Avatar
Those specs are what I get in mine. I run non synthetic oil. Had issues in a few front axles with leaking oil out the tubes. Since switching to reg dino oil, no leaks at all.
jason mac is offline
post #3 of 5 Old 02-24-2014, 07:51 PM
10jk's Avatar
Check it for foaming/brown chocolate milk looking after water runs. Use the cheap stuff at walmart, especially if ya change it often.
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #4 of 5 Old 02-24-2014, 08:44 PM
Rubiconquered's Avatar
That's the same that I got when I changed my gear oil a few weeks ago.
One quart up front 2 in the rear. I drove it for a few days and re checked and is still full front and rear. Same thing full synthetic but I used valvoline.
Sent from inside the Death Star
CRAWLIN PERFORMANCE 602-552-6793
Rubiconquered is offline
post #5 of 5 Old 02-24-2014, 09:27 PM
ronjenx's Avatar
Here are the factory differential capacities for the JK:
FRONT AXLE .03 L (1 oz.)
186 FBI (Model 30) 1.0 L (1.05 qts)
216 FBI (Model 44) 1.3 L (1.35 qts)
REAR AXLE .03 L (1 oz.)
198 RBI (Model 35) 1.83 L (1.9 qts)
226 RBI (Model 44) 2.25 L (2.4 qts)
Actual amounts from factory on my vehicle:
Front Dana 44: 44oz (15oz above bottom of fill hole) (1.4 qts)
Rear Dana 44: 72oz (slightly above bottom of fill hole) (2.25 qts)
When I service mine, I fill it to the level it was from the factory.
It wasn't leaking, foaming, or blowing out the vent, and it isn't doing so now.
I figure the extra fluid is keeping the seals wet, maybe preventing leakage.
ronjenx is offline
