pulling to the left hard while driving straight - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 02-16-2014, 08:41 AM Thread Starter
Bakerlg71's Avatar
Yesterday I was driving down the highway and all the sudden my Jeep pulled hard to the left. I pulled over to see if something was frozen as I just came off the trail. Nothing that I could see was wrong. I went back to town later and it did it again and wouldn't let me turn right at all. I finally got it to go and stopped at a stop sign turned right and part way thrift the turn it pulled left and as I was trying to finish the turn if made a bang noise in the front and let me turn. Today I put it in 44 to make it up a driveway and if started banging in the front like it was shipping. Has anyone ever heard of this or had this happen so maybe I can look in the right direction?
Bakerlg71 is offline
post #2 of 10 Old 02-16-2014, 09:22 AM
Guruman's Avatar
Axle u-joint bad or seizing maybe?
_
Guruman is offline
post #3 of 10 Old 02-16-2014, 09:31 AM Thread Starter
Bakerlg71's Avatar
Do you think that would make it pull all of a sudden going down the road straight?
post #4 of 10 Old 02-16-2014, 09:44 AM
Guruman's Avatar
Maybe. If the u-joint was broken or damaged it might stick or jam together, causing that one side to make terrible noises and have a lot of resistance. I could see it causing you to veer.
It's also possible it's a brake (or traction control/ABS issue), but I would not expect that to make a lot of noise (other than the ABS pump running).
If it's pulling to one side, that's the side I'd look on first.
_
Guruman is offline
post #5 of 10 Old 02-16-2014, 10:02 AM Thread Starter
Bakerlg71's Avatar
That's where I will start. Thanks for your input.
post #6 of 10 Old 02-16-2014, 08:04 PM
ockgator's Avatar
Check them ball joints while you're down there
Proud to be deplorable
ockgator is offline
post #7 of 10 Old 02-16-2014, 09:26 PM
Landoom's Avatar
Sounds like a u-joint in the front axle to me.
If it ain't broke, don't fix it. If you don't like it, go break it!
'07 JKRU
3.5" RK X-Factor Lift on 37x12.5x17 MTR-K's wrapped around AEV Pintler Wheels
Landoom is offline
post #8 of 10 Old 02-17-2014, 02:53 AM Thread Starter
Bakerlg71's Avatar
It has new Synergy ball joints only about a month old. I'm thinking you guys are right on the ball joints I will get some and pull the cover also to check the ring and pinion!
post #9 of 10 Old 02-19-2014, 04:05 AM Thread Starter
Bakerlg71's Avatar
This is my problem!
Her is my problem. First time I've ever had something like this happen.
post #10 of 10 Old 02-19-2014, 07:10 AM
Guruman's Avatar
OK, I was definitely not expecting that....
Glad you found it.
_
Guruman is offline
